NAME | Synopsis | Description | Options | Operands | Examples | Exit Status | See Also
list [--terse={true|false}][ --echo={true|false} ] [ --interactive={true|false} ] [ --host host] [--port port] [--secure| -s ] [ --user admin_user] [--passwordfile filename] [--help] [ --monitor =false] [dotted_parent_attribute_name]
Lists the configurable element. On Solaris, quotes are needed when executing commands with * as the option value or operand.
The dotted notation follows these guidelines:
Any list command that has a dotted name that is not followed by a wildcard (*) will get, as its result, the current node's immediate children. For example, list --monitor server lists all immediate children belonging to the server node.
Any list command that has a dotted name followed by a wildcard(*) will get, as its result, a hierarchical tree of children nodes from the current node. For example, list --monitor server.applications.* will list all children of applications and their subsequent child nodes and so on.
Any list command that has a dotted name preceded or followed by a wildcard (*) of the form *dotted name or dotted * name or dotted name* will get, as its result, all nodes and their children matching the regular expression created by the provided matching pattern.
An application server dotted name uses the “.” (period) as a delimiter to separate the parts of a complete name. This is similar to how the “/” character is used to delimit the levels in the absolute path name of a file in the UNIX file system. The following rules apply while forming the dotted names accepted by the get, set and list commands. Note that a specific command has some additional semantics applied.
A . (period) always separates two sequential parts of the name.
A part of the name usually identifies an application server subsystem and/or its specific instance. For example: web-container, log-service, thread-pool-1 etc.
If any part of the name itself contains a . (period), then it must be escaped with a leading \ (backslash) so that the “.” does not act like a delimiter.
An * (asterisk) can be used anywhere in the dotted name and it acts like the wildcard character in regular expressions. Additionally, an * can collapse all the parts of the dotted name. Long dotted name like "this.is.really.long.hierarchy" can be abbreviated to "th*.hierarchy". But note that the . always delimits the parts of the name.
The top level switch for any dotted name is -monitor or -m that is separately specified on a given command line. The presence or lack of this switch implies the selection of one of the two hierarchies for appserver management: monitoring and configuration.
If you happen to know the exact complete dotted name without any wildcard character, then list and get/set have a little difference in their semantics:
The list command treats this complete dotted name as the complete name of a parent node in the abstract hierarchy. Upon providing this name to list command, it simply returns the names of the immediate children at that level. For example, list server.applications.web-module will list all the web modules deployed to the domain or the default server.
The get and set commands treat this complete dotted name as the fully qualified name of the attribute of a node (whose dotted name itself is the name that you get when you remove the last part of this dotted name) and it gets/sets the value of that attribute. This is true if such an attribute exists. You will never start with this case because in order to find out the names of attributes of a particular node in the hierarchy, you must use the wildcard character *. For example, server.applications.web-module.JSPWiki.context-root will return the context-root of the web-application deployed to the domain or default server.
server(usually the first part of the complete dotted name) can be replaced with the name of a particular server instance of interest (e.g., server1) and you'll get the information of that server instance, remaining part of the dotted name remaining the same. Note that the dotted names that are available in such other server instances are those from the monitoring hierarchy because these server instances don't have a way to expose the configuration hierarchy.
The list command is the progenitor of navigational capabilities of these three commands. If you want to set or get attributes of a particular application server subsystem, you must know its dotted name. The list command is the one which can guide you to find the dotted name of that subsystem. For example, to find out the modified date (attribute) of a particular file in a large file system that starts with /. First you must find out the location of that file in the file system, and then look at its attributes. Therefor, two of the first commands to understand the hierarchies in appserver are: * list "*" and * list * -monitor. The sorted output of these commands is typically of the following form:
Consequently, the list command is the entry point into the navigation of the application server's s management hierarchies. Take note of the output of the list command:
The output lists one element per line.
Every element on a line is a complete-dotted-name of a management component that is capable of having attributes. Note that none of these lines show any kind of attributes at all.
The output of thelist command is a list of dotted names representing individual application server components and subsystems. Every component or subsystem is capable of having zero or more attributes that can be read and modified.
With thelist command you can drill down through the hierarchy in a particular branch of interest. For example, if you want to find the configuration of the http-listener of the domain (the default server, whose ID is "server"). Here is how you could proceed on a UNIX terminal:
Making use of both list and get commands, it is straightforward to reach a particular component of interest.
To get the monitoring information of a particular subsystem you must:
Use the set command to set an appropriate monitoring level for the component of interest.
Obtain the various information about the JVM that the application server domain is running.
ID |
Command |
Output/Comment |
1 |
list server* | grep monitoring |
server-config.monitoring-serviceserver-config.monitoring-service.module-monitoring-levelsserver.monitoring-serviceserver.monitoring-service.module-monitoring-levels Note that this is the list command. It only shows the hierarchy, nothing else. Using the '|' and "grep" narrows down the search effectively. Now, you can choose server.monitoring-service to set the attributes of various attributes that can be monitored. This is the configuration data because this setting will be persisted to the server's configuration store. |
2 |
get server.monitoring-service.* |
You can try the number of attributes that are presently available with monitoring service. Here is the output: No matches resulted from the wildcard expression. This is because this fully dotted name does not have any attributes at all. Logically, you try the next one and that is: server.monitoring-service.module-monitoring-levels. Again, use the wildcard character to get ALL the attributes of a particular component. |
3 |
get server.monitoring-service.module-monitoring-levels.* |
server.monitoring-service.module-monitoring-levels.connector-connection-pool = OFF server.monitoring-service.module-monitoring-levels.connector-service = OFF server.monitoring-service.module-monitoring-levels.ejb-container = OFF server.monitoring-service.module-monitoring-levels.http-service = OFF server.monitoring-service.module-monitoring-levels.jdbc-connection-pool = OFF server.monitoring-service.module-monitoring-levels.jms-service = OFF server.monitoring-service.module-monitoring-levels.jvm = OFF server.monitoring-service.module-monitoring-levels.orb = OFF server.monitoring-service.module-monitoring-levels.thread-pool = OFF server.monitoring-service.module-monitoring-levels.transaction-service = OFF server.monitoring-service.module-monitoring-levels.web-container = OFF The JVM monitoring is at a level OFF. It must be changed in order to make the JVM monitoring information available. The other valid values for all the monitoring level are: LOW and HIGH. use the set command to set the value appropriately. |
4 |
set server.monitoring-service.module-monitoring-levels.jvm=HIGH There is no space before or after the = sign. |
server.monitoring-service.module-monitoring-levels.jvm = HIGH Now, the JVM information can be obtained using the get command and monitoring switch. But remember , when you switch to the monitoring hierarchy, start with the list command again. |
5 |
list --monitor * | grep jvm |
server.jvm server.jvm.class-loading-system server.jvm.compilation-system server.jvm.garbage-collectors server.jvm.garbage-collectors.Copy server.jvm.garbage-collectors.MarkSweepCompact server.jvm.memory server.jvm.operating-system server.jvm.runtime server.jvm.thread-system server.jvm.thread-system.thread-1 . . . server.jvm.thread-system.thread-793823 server.jvm.thread-system.thread-793824 server.jvm.thread-system.thread-793825 server.jvm.thread-system.thread-793826 server.jvm.thread-system.thread-793827 server.jvm.thread-system.thread-9 The JRE 1.5.0 monitorable components are exposed in an elegant manner. This is what you see when connected by the JConsole. Now, to know more about the class-loading system in the JVM, this is how you'll proceed. Note that now you are interested in the attributes of a particular leaf node. Thus the command is get not list. |
6 |
get -monitor server.jvm.class-loading-system.* |
server.jvm.class-loading-system.dotted-name = server.jvm.class-loading-system server.jvm.class-loading-system.loadedclasscount-count = 7328 server.jvm.class-loading-system.loadedclasscount-description = No Description was available server.jvm.class-loading-system.loadedclasscount-lastsampletime = 1133819508973 server.jvm.class-loading-system.loadedclasscount-name = LoadedClassCount? server.jvm.class-loading-system.loadedclasscount-starttime = 1133819131268 server.jvm.class-loading-system.loadedclasscount-unit = count server.jvm.class-loading-system.totalloadedclasscount-count = 10285 server.jvm.class-loading-system.totalloadedclasscount-description = No Description was available server.jvm.class-loading-system.totalloadedclasscount-lastsampletime = 1133819508972 server.jvm.class-loading-system.totalloadedclasscount-name = TotalLoadedClassCount? server.jvm.class-loading-system.totalloadedclasscount-starttime = 1133819131268 server.jvm.class-loading-system.totalloadedclasscount-unit = count server.jvm.class-loading-system.unloadedclasscount-count = 2957 server.jvm.class-loading-system.unloadedclasscount-description = No Description was available server.jvm.class-loading-system.unloadedclasscount-lastsampletime = 1133819508973 server.jvm.class-loading-system.unloadedclasscount-name = UnloadedClassCount? server.jvm.class-loading-system.unloadedclasscount-starttime = 1133819131268 server.jvm.class-loading-system.unloadedclasscount-unit = count You cansee that 10285 is the total number of classes loaded by the Virtual Machine. Whereas, 2957 is number of classes unloaded, since it was started. ,Similarly, you can explore attributes of the other subsystems as well. |
Indicates that any output data must be very concise, typically avoiding human-friendly sentences and favoring well-formatted data for consumption by a script. Default is false.
Setting to true will echo the command line statement on the standard output. Default is false.
If set to true (default), only the required password options are prompted.
The machine name where the domain administration server is running. The default value is localhost.
The HTTP/S port for administration. This is the port to which you should point your browser in order to manage the domain. For example, http://localhost:4848.
The default port number is 4848.
If set to true, uses SSL/TLS to communicate with the domain administration server.
The authorized domain administration server administrative username.
If you have authenticated to a domain using the asadmin login command, then you need not specify the --user option on subsequent operations to this particular domain.
The --passwordfile option specifies the name, including the full path, of a file containing the password entries in a specific format. The entry for the password must have the AS_ADMIN_ prefix followed by the password name in uppercase letters.
For example, to specify the domain administration server password, use an entry with the following format: AS_ADMIN_PASSWORD=password, where password is the actual administrator password. Other passwords that can be specified include AS_ADMIN_MAPPEDPASSWORD, AS_ADMIN_USERPASSWORD, and AS_ADMIN_ALIASPASSWORD.
All remote commands must specify the admin password to authenticate to the domain administration server, either through --passwordfile or asadmin login, or interactively on the command prompt. The asadmin login command can be used only to specify the admin password. For other passwords, that must be specified for remote commands, use the --passwordfile or enter them at the command prompt.
If you have authenticated to a domain using the asadmin login command, then you need not specify the admin password through the --passwordfile option on subsequent operations to this particular domain. However, this is applicable only to AS_ADMIN_PASSWORD option. You will still need to provide the other passwords, for example, AS_ADMIN_USERPASSWORD, as and when required by individual commands, such as update-file-user.
For security reasons, passwords specified as an environment variable will not be read by asadmin.
The default value for AS_ADMIN_MASTERPASSWORD is changeit.
Displays the help text for the command.
defaults to false; if set to false, the configurable attribute values are returned. If set to true, the monitorable attribute values are returned.
asadmin> list --user admin --passwordfile password.txt --port 5001 "*" server server.admin-service server.admin-service.das-config server.application-ref.MEjbApp server.application-ref.__ejb_container_timer_app server.application-ref.adminapp server.application-ref.admingui server.application-ref.com_sun_web_ui server.applications server.applications.j2ee-application.MEjbApp server.applications.j2ee-application.__ejb_container_timer_app server.applications.web-module.adminapp server.applications.web-module.admingui server.applications.web-module.com_sun_web_ui server.ejb-container server.http-service server.http-service.http-listener.admin-listener server.http-service.http-listener.http-listener-1 server.http-service.http-listener.http-listener-2 server.iiop-service server.iiop-service.iiop-listener.SSL server.iiop-service.iiop-listener.SSL.ssl server.iiop-service.iiop-listener.SSL_MUTUALAUTH server.iiop-service.iiop-listener.SSL_MUTUALAUTH.ssl server.iiop-service.iiop-listener.orb-listener-1 server.iiop-service.orb server.java-config server.jms-service server.jms-service.jms-host.default_JMS_host server.log-service server.log-service.module-log-levels server.mdb-container server.monitoring-service server.monitoring-service.module-monitoring-levels server.resource-ref.jdbc/PointBase server.resource-ref.jdbc/__TimerPool server.resources server.resources.jdbc-connection-pool.PointBasePool server.resources.jdbc-connection-pool.__TimerPool server.resources.jdbc-resource.jdbc/PointBase server.resources.jdbc-resource.jdbc/__TimerPool server.security-service server.security-service.audit-module.default server.security-service.auth-realm.certificate server.security-service.auth-realm.file server.security-service.jacc-provider.default server.thread-pools server.thread-pools.thread-pool.thread-pool-1 server.transaction-service server.virtual-server.__asadmin server.virtual-server.server server.web-container |
asadmin> list --user admin --passwordfile password.txt --host localhost --port 4848 server.applications.j2ee-application server.applications.j2ee-application.MEjbApp server.applications.j2ee-application._ejb_container_timer_app server.applications.j2ee-application.stateless-simple |
asadmin> list --user admin --passwordfile password.txt --host localhost --port 4848 server.applications.web-module server.applications.web-module.adminapp server.applications.web-module.adminguip server.applications.web-module.com_sun_web_ui |
