NAME | Synopsis | Description | Options | Operands | Examples | Exit Status | See Also
start-domain [--domaindir domain-dir] --user admin_user --passwordfile file_name [--terse={true|false}] [ --echo ={true|false}] [ --interactive ={true|false}] [ --verbose ={true|false}] [ --debug ={true|false}] [domain_name]
Use the start-domain command to start a domain. If the domain directory is not specified, the domain in the default install_dir/domains directory is started. If there are two or more domains, the domain_name operand must be specified.
You can use the start-domain command to upgrade domains of Application Server 8.x or 9.0 to Application Server 9.1. Use one of the following ways to upgrade your domain:
Perform an in-place upgrade of the Application Server binaries. When you run start-domain on the domains pointing to the earlier version of Application Server, asadmin invokes the asupgrade command, and the domains are automatically upgraded in-place.
Perform a side-by-side upgrade of the Application Server binaries. Run start-domain on the domains of your earlier installation. The asupgrade command upgrades the domains to the domains root of the latest Application Server installation. In this scenario, the target directory for the upgrade is defined in the AS_DEF_DOMAINS_PATH in the asenv.conf.
On the Mac OS X platform, processes can bind to the same port. To avoid this problem, do not start multiple domains with the same port number at the same time.
This command is supported in local mode only.
The directory where the domain is to be started. If specified, the path must be accessible in the filesystem. If not specified, the domain in the default install_dir/domains directory is started.
The authorized domain application server administrative username.
The file containing the domain application server password associated with the administrative instance. The password is defined in the following form: AS_ADMIN_PASSWORD=password. Where password is the actual administrator password for the domain.
Indicates that any output data must be very concise, typically avoiding human-friendly sentences and favoring well-formatted data for consumption by a script. Default is false.
Setting to true will echo the command line statement on to the standard output. Default is false.
If set to true (default), only the required password options are prompted.
By default this flag is set to false. If set to true, detailed server startup output is displayed. On Windows, press CTRL-Break in the domain's window to print a thread dump. On UNIX, press CTRL-C to kill the server and press CTRL-\\ to print a thread dump.
By default this flag is set to false. If set to true, the server is started in debug mode and prints the JPDA port on the console.
asadmin> start-domain domain1 Starting Domain domain1, please wait. Log redirected to /usr/appserver/domains/domain1/logs/server.log. Redirecting output to /usr/appserver/domains/domain1/logs/server.log Domain domain1 started. Domain [domain1] is running [Sun Java System Application Server 9.1 (build b50d-beta3)] with its configuration and logs at: [/usr/appserver/domains]. Admin Console is available at [http://localhost:4848]. Use the same port [4848] for "asadmin" commands. User web applications are available at these URLs: [http://localhost:8080 https://localhost:8181 ]. Following web-contexts are available: [/web1 /__wstx-services ]. Standard JMX Clients (like JConsole) can connect to JMXServiceURL: [service:jmx:rmi:///jndi/rmi://pdavies.SFBay.Sun.COM:8686/jmxrmi] for domain management purposes. Domain listens on at least following ports for connections: [8080 8181 4848 3700 3820 3920 8686 ]. Domain supports application server clusters and other standalone instances. |
Where: domain1 is the domain in the /usr/appserver/domains directory.
