Using the BPEL Designer and Service Engine
BPEL Designer and Service Engine Features
This section contains the following information:
BPEL Service Engine Features
Following features are supported by the BPEL Service Engine:
Supported WS-BPEL 2.0 Constructs
The following WS-BPEL 2.0 constructs are inplemented by the BPEL Service Engine
Features
Support
Process
WS-BPEL 2.0 process root element. The Process element is present in the BPEL Designer diagram by default.
Supported Elements
    extensions
    import
    partnerLinks
    variables
    correlationSets
    faultHandlers
    eventHandlers
Supported Attributes
    name
    targetNamespace
Not Supported
    queryLanguage (xpath only)
    expressionLanguage (xpath only)
    suppressJoinFailure
    abstractProcess
    exitOnStandardFault
Extensions
More Information
Variable
Supplies the mechanism used to hold messages that make up the state of a business process.
Supported Elements
    name
    messageType
    type
    element
Extensions
More Information
Correlation
Tracks the multiple long-running exchanges of messages that typically take place between a BPEL process and its partner services. The correlation mechanism helps to route messages to appropriate process instances.
Supported Elements
Extensions
More Information
EventHandlers
Invokes a specific action concurrently with a specified corresponding event.
Supported Elements
    onEvent
    onAlarm
Extensions
More Information
FaultHandlers
Defines the activities that are executed as a response to faults resulting from invoked services.
Supported Elements
    catch
    catchAll
Extensions
More Information
Import
Used within a process to clearly express dependency upon external XML Schema or WSDL definitions. The Process element can have any number of Import elements as initial children, preceeding any other child element.
Supported Elements
    namespace
    location
    importType
Extensions
More Information
Web Services
Invoke
Invokes a one-way or request-response operation on a portType offered by a partner. It enables the business process to send messages to partners. The operation is defined in the partner's WSDL file.
Supported Elements
    correlations
    toPart
    fromPart
Not Supported
    catch
    catchAll
    compensationHandler
    partnerLink
    portType
    operation
    inputVariable
    outputVariable
Extensions
More Information
Receive
Allows the business process to do a blocking wait for a particular message to arrive.
Supported Elements
    correlations
    fromPart
    partnerLink
    portType
    operation
    Variable
    createInstance
    messageExchange
Extensions
More Information
Reply
Returns a message from the process to the same partner that initiated the operation. The combination of Receive and Reply activities creates a request-response operation.
Supported Elements
    correlations
    toPart
    partnerLink
    portType
    operation
    Variable
    faultName
    messageExchange
Extensions
More Information
PartnerLink
Identifies the parties that interact with your business process. Each link is defined by a partner link type and a role name.
Supported Elements
    name
    partnerLinkType
    myRole
    partnerRole
Not Supported
    initializePartnerRole
Extensions
More Information
Basic Activities
Assign
Assigns values to variables. You use the Assign element to copy data from one variable to another, construct and calculate the values of expressions, and store new data in variables. Expressions are required to perform simple computation or operate message selections, properties, and literal constants to produce a new value for variables.
Supported Elements
    copy (child elements from and to)
    extensibleAssign
    from (name="variable" type="NCName")
    from (name="part" type="NCName")
    to (name="variable" type="NCName")
    to (name="part" type="NCName")
    validate
    from (name="expressionLanguage" type="anyURI" — xpath only)
    from (name="property" type="QName")
    from (name="partnerLink" type="NCName")
    from (name="endpointReference" type="bpws:tRoles")
    from (name="opaque" type="bpws:tBoolean")
    to (name="queryLanguage" type="anyURI")
    to (name="property" type="QName")
    to (name="partnerLink" type="NCName")
Extensions
More Information
JavaScript
Acts like an Assign activity that enables you to use JavaScript (E4X), rather than using XPath 1.0.
Supported Elements
    extensibleAssign
    Validate
Extensions
More Information
Validate
Validates the values of variables against their associated XML and WSDL data definition. The element includes a Variables property that lists the variables for the process, and allows you to specify which variables to validate. When one or more variables prove invalid against a corresponding XML definition, a standard fault, bpel:invalidVariables, is thrown.
Supported Elements
    variable
Extensions
More Information
Empty
Used as a placeholder within a process to catch and suppress faults or to help synchronize actions within a flow activity that are executed concurrently.
Supported Elements
Extensions
More Information
Wait
Waits for a specified time or until a deadline is reached.
Supported Elements
    for
    until
Extensions
More Information
Throw
Used to signal a specific internal fault, and can provide a QName and information for that fault.
Supported Elements
    faultName
    faultVariable
Extensions
More Information
ReThrow
Used to rethrow a fault.
Supported Elements
Extensions
More Information
Exit
Terminates the execution of a business process instance.
Supported Elements
Extensions
More Information
Compensate
Invokes the compensation handler of a particular scope.
Supported Elements
Extensions
More Information
CompensateScope
Supported Elements
Extensions
More Information
Structured Activities
If
Supports conditional behavior of a business process instance. The If activity consists of conditional branches defined by the If and Else If elements, followed by an optional Else branch. The conditions on If and Else If branches are evaluated in the order they appear. During execution, the first branch whose condition holds true is taken and provides the activity specified for the If activity. In other words, if there are several Else If branches whose conditions hold true, only the first of them will be executed.
Supported Elements
    elseIf
    condition
Extensions
More Information
While
Repeatedly execute one or more activities as long as specific conditions are in place at the beginning of each iteration.
Supported Elements
    condition
Extensions
More Information
RepeatUntil
Repeatedly executes one or more activities as long as specific conditions are in place after the execution of each iteration. This element contains other elements that are repeated until the success criteria you specify are met. If the condition you specify leads to true, the activities listed will be executed once.
Supported Elements
    condition
Extensions
More Information
ForEach
Repeatedly execute its contained scope activity exactly N+1 times where N equals the Final Counter Value minus the Start Counter Value.
Supported Elements
    startCounterValue
    finalCounterValue
    completionCondition
    counterName
Not Supported
    parallel
Extensions
More Information
Pick
Blocks a process and waits until a specified events occurs. After one of the specific event occurs, the activity associated with this event is performed. The possible events are the arrival of a message or a timer-based alarm. The selected activity is dependent upon which event occurs first.
Supported Elements
    onMessage
    onAlarm
    variable
Extensions
More Information
Flow
Defines a set of activities that will execute concurrently (in parallel). This is a structured activity, containing other activities separated into individual control paths or branches. You can embed as many paths in the activity as you want, and they will all be executed simultaneously.
Supported Elements
Not Supported
    links
Extensions
More Information
Sequence
Used to nest a series of activities in a process. Activities within a sequence execute in strict sequential order, completing when the last activity within the nest has finished.
Supported Elements
Extensions
More Information
Scope
Essentially, this activity is a collection of child activities that can have their own Variables, Fault and Event Handlers, and correlation sets. The Scope activity provides the behavior context for the child elements.
Supported Elements
    variables
    faultHandlers
    eventHandlers
Not Supported
    partnerLinks
    correlationSets
    compensationHandler
    terminationHandler
Not Supported
    isolated
    exitOnStandardFault
Extensions
More Information
Other Activities
OnMessage
Supported Elements
    variable
Extensions
More Information
OnMsgCommon
Supported Elements
    fromPart
    correlations
    partnerLink
    portType
    operation
    messageExchange
Extensions
More Information
OnAlarmPick
Specifies an event that is triggered when a given duration variable is exceeded.
Supported Elements
Extensions
More Information
CompletionCondition
Supported Elements
    countCompletedBranchesOnly
Extensions
More Information
Catch
Used to intercept a specifically defined type of fault.
Supported Elements
    faultName
    faultVariable
    faultMessageType
    faultElement
Extensions
More Information
OnEvent
Indicates that a specified event is triggered when a message arrives.
Supported Elements
    messageType
    variable
Extensions
More Information
Activity
Supported Elements
Not Supported
    targets
    sources
    name
Not Supported
    suppressJoinFailure
Extensions
More Information
property
Defines a unique name and associates it with an XML Schema simple type.
Supported Elements
    name
    type
    element
Extensions
More Information
propertyAlias
Defines a globally named property as an alias.
Supported Elements
    query
    propertyName
    messageType
    part
Not Supported
Extensions
More Information
PartnerLinkType
Expresses the dependences between services by defining each service's role.
Supported Elements
    role
    name
Extensions
More Information
Role
Specifies one WSDL portType.
Supported Elements
    name
    portType
Extensions
More Information
CorrelationWithPattern
Supported Elements
Extensions
More Information
