As with resource type properties, you declare resource properties in the RTR file. By convention, resource property declarations follow the resource type declarations in the RTR file. The syntax for resource declarations is a set of attribute value pairs enclosed by curly brackets:
{ Attribute = Value; Attribute = Value; . . . Attribute = Value; } |
For resource properties provided by Sun Cluster, so-called system-defined properties, you can change specific attributes in the RTR file. For example, Sun Cluster provides method timeout properties for each of the callback methods, and specifies default values. In the RTR file, you can specify different default values.
You can also define new resource properties in the RTR file, so-called extension properties, using a set of property attributes provided by Sun Cluster. Table A–4 lists the attributes for changing and defining resource properties. Extension property declarations follow the system-defined property declarations in the RTR file.
The first set of system-defined resource properties specifies timeout values for the callback methods:
... # Resource property declarations appear as a list of bracketed # entries after the resource-type declarations. The property # name declaration must be the first attribute after the open # curly bracket of a resource property entry. # # Set minimum and default for method timeouts. { PROPERTY = Start_timeout; MIN=60; DEFAULT=300; } { PROPERTY = Stop_timeout; MIN=60; DEFAULT=300; } { PROPERTY = Validate_timeout; MIN=60; DEFAULT=300; } { PROPERTY = Update_timeout; MIN=60; DEFAULT=300; } { PROPERTY = Monitor_Start_timeout; MIN=60; DEFAULT=300; } { PROPERTY = Monitor_Stop_timeout; MIN=60; DEFAULT=300; { PROPERTY = Monitor_Check_timeout; MIN=60; DEFAULT=300; } |
The name of the property (PROPERTY = value) must be the first attribute for each resource-property declaration. You can configure resource properties, within limits defined by the property attributes in the RTR file. For example, the default value for each method timeout in the sample is 300 seconds. An administrator can change this value; however, the minimum allowable value, specified by the MIN attribute, is 60 seconds. See Table A–4 for a complete list of resource property attributes.
The next set of resource properties defines properties that have specific uses in the data service.
{ PROPERTY = Failover_mode; DEFAULT=SOFT; TUNABLE = ANYTIME; } { PROPERTY = Thorough_Probe_Interval; MIN=1; MAX=3600; DEFAULT=60; TUNABLE = ANYTIME; } # The number of retries to be done within a certain period before concluding # that the application cannot be successfully started on this node. { PROPERTY = Retry_Count; MAX=10; DEFAULT=2; TUNABLE = ANYTIME; } # Set Retry_Interval as a multiple of 60 since it is converted from seconds # to minutes, rounding up. For example, a value of 50 (seconds) # is converted to 1 minute. Use this property to time the number of # retries (Retry_Count). { PROPERTY = Retry_Interval; MAX=3600; DEFAULT=300; TUNABLE = ANYTIME; } { PROPERTY = Network_resources_used; TUNABLE = WHEN_DISABLED; DEFAULT = ""; } { PROPERTY = Scalable; DEFAULT = FALSE; TUNABLE = AT_CREATION; } { PROPERTY = Load_balancing_policy; DEFAULT = LB_WEIGHTED; TUNABLE = AT_CREATION; } { PROPERTY = Load_balancing_weights; DEFAULT = ""; TUNABLE = ANYTIME; } { PROPERTY = Port_list; TUNABLE = AT_CREATION; DEFAULT = ; }
These resource-property declarations add the TUNABLE attribute, which limits the occasions on which the system administrator can change their values. AT_CREATION means the administrator can only specify the value when the resource is created and cannot change it later.
For most of these properties you can accept the default values as generated by Agent Builder unless you have a reason to change them. Information about these properties follows (for additional information, see Resource Properties or the r_properties(5) man page):
Indicates whether the RGM should relocate the resource group or abort the node in the case of a failure of a Start or Stop method.
Used in the fault monitor. The tunability is anytime, so a system administrator can adjust them if the fault monitor is not functioning optimally.
A list of logical hostname or shared address resources used by the data service. Agent Builder declares this property so a system administrator can specify a list of resources, if there are any, when configuring the data service.
Set to FALSE to indicate this resource does not use the cluster networking (shared address) facility. This setting is consistent with the resource type Failover property set to TRUE to indicate a failover service. See Implementing a Failover Resource and Implementing a Scalable Resource for additional information about how to use this property.
Automatically declares these properties, however, they have no use in a failover resource type.
Identifies the list of ports on which the server is listening. Agent Builder declares this property so a system administrator can specify a list of ports, when configuring the data service.
