Sun Cluster 3.0-3.1 With Sun StorEdge 9900 Series Storage Device Manual
Chapter 2 Installing Multipathing Software in a Sun StorEdge 9900 Series Storage Array
This chapter contains procedures on how to install and add multipathing software. Multipathing software enables you to define and control redundant physical paths to I/O devices such as storage arrays and networks. If the active path to a device becomes unavailable, the multipathing software can automatically switch to an alternate path to maintain availability. This capability is known as automatic failover. To maximize multipathing capabilities, your servers must be configured with redundant hardware. Redundant hardware includes redundant network interfaces or two host bus adapters that are connected to the same dual-ported storage array.
This chapter contains the following procedures.
This section contains procedures on how to install multipathing software in a cluster that isnot yet installed with Sun Cluster software. Choose one of the following multipathing solutions.
ProcedureSPARC: How to Install Sun StorEdge 9900 Dynamic Link Manager Software
Use this procedure to install Sun StorEdge 9900 Dynamic Link Manager (Sun SDLM) software in a cluster that is not yet installed with Sun Cluster software. This procedure assumes that you installed Solaris Operating System. If your cluster is already running Sun Cluster software, see Adding Multipathing Software to add multipathing software to a running cluster.
Perform this procedure on one node at a time. This procedure defines Node N as the node on which you are installing the multipathing software.
Steps
  1. Install the new storage array.
    For instructions on how to install the storage array, see the documentation that shipped with your storage array.
  2. Configure the storage array such that each node has two paths to the same set of LUNs. For an example configuration, see Figure 2–1.
    Contact your service provider to create the desired logical volumes. These new logical volumes can be configured by using LUN Expansion (LUSE) or Virtual LVI/LUN.
    Figure 2–1 SPARC: Switched Configuration
    Illustration: The preceding context describes the graphic.
  3. On each node that is connected to the storage array, use the format(1M) command. Use this command to verify that the same set of LUNs is visible to the expected controllers.
    # format
    See the format command man page for more information about by using the command.
  4. Install and configure Sun SDLM software.
    For instructions on how to install and configure the Sun SDLM software, see the documentation that shipped with your storage array.
  5. Did you perform a reconfiguration reboot when you configured Sun SDLM software?
    • If yes, proceed to Step 6.
    • If no, shut down Node N, and perform a reconfiguration reboot to create the new Solaris device files and links on Node N.
      # boot -r
  6. On each node connected to the storage array, use the format(1M) command. Use this command to verify that you see half the number of disks you saw in Step 3.
    # format
  7. On all remaining nodes and one node at a time, repeat Step 1 through Step 6.
See Also
After you install multipathing software, you might want to install Sun Cluster software. For the procedures on how to install Sun Cluster software, see Sun Cluster software installation documentation.
ProcedureHow to Install Sun StorEdge Traffic Manager Software
Use this procedure to install Sun StorEdge Traffic Manager software in a cluster that is not yet installed with Sun Cluster software. This procedure assumes that you installed Solaris Operating System. If your cluster is already running Sun Cluster software, see Adding Multipathing Software to add multipathing software to a running cluster.
Steps
  2. Configure the storage array so that each node has two paths to the same set of LUNs. For an example configuration, see Figure 2–2.
    Figure 2–2 Switched Configuration
  3. On each node connected to the storage array, use the format(1M) command. Use this command to verify that the same set of LUNs is visible to the expected controllers.
    # format
  4. Install any required patches or software for Sun StorEdge Traffic Manager software support to nodes and enable multipathing.
    For the procedure about how to install the Sun StorEdge Traffic Manager software, see How to Install Sun Multipathing Software in Sun Cluster Software Installation Guide for Solaris OS.
  5. Boot Node N.
    For more information on booting nodes, see Sun Cluster software installation documentation.
  6. Did you perform a reconfiguration reboot when you configured Sun StorEdge Traffic Manager software?
    • If yes, proceed to Step 7.
  7. On each node connected to the storage array, use the format(1M) command. Use this command to verify that you see half the number of disks you saw in Step 3.
    # format
  8. On all remaining nodes and one node at a time, repeat Step 1 through Step 7.
See Also
After you install multipathing software, you might want to install Sun Cluster software. For the procedure on how to install Sun Cluster software, see Sun Cluster software installation documentation .
This section contains a procedure on how to add multipathing software in a running cluster. Choose one of the following multipathing solutions.
ProcedureSPARC: How to Add Sun StorEdge 9900 Dynamic Link Manager Software
Use this procedure to add Sun StorEdge 9900 Dynamic Link Manager (Sun SDLM) software in a running cluster.
Do not use this procedure to convert from host-based mirroring to a multipathing solution. For the procedure on how to convert from host-based mirroring to a multipathing solution, contact your Sun service provider.
Before You Begin
This procedure assumes that you installed and configured your storage array. If you have not installed your storage array, see SPARC: How to Install Sun StorEdge 9900 Dynamic Link Manager Software to add multipathing software and the storage array at the same time.
Steps
  1. Determine the resource groups and device groups that are running on Node N.
    Record this information because you use this information in Step 11 of this procedure to return resource groups and device groups to these nodes.
    # scstat
    For more information, see the Sun Cluster system administration documentation.
  2. Move all resource groups and device groups off Node N.
    # scswitch -S -h from-node
  3. Do you need to install additional physical paths between Node N and the storage?
    Note –
    If you use multipathing software, each node requires two paths to the same set of LUNs. For an example configuration, see Figure 2–1.
    For the procedure on how to install host adapters, see the documentation that shipped with your host adapters and nodes.
  4. Shut down and power off Node N.
    For the full procedure on how to shut down and power off a node, see Sun Cluster system administration documentation.
  5. Install the host adapters and the cables between Node N and the storage.
  6. Power on and boot Node N into non-cluster mode.
    For more information on booting nodes, see Sun Cluster system administration documentation.
  7. If necessary, upgrade the host adapter firmware on Node N.
    PatchPro is a patch-management tool that eases the selection and download of patches required for installation or maintenance of Sun Cluster software. PatchPro provides an Interactive Mode tool especially for Sun Cluster. The Interactive Tool makes the installation of patches easier. PatchPro's Expert Mode tool helps you to maintain your configuration with the latest set of patches. Expert Mode is especially useful for obtaining all of the latest patches, not just the high availability and security patches.
    To access the PatchPro tool for Sun Cluster software, go to http://www.sun.com/PatchPro/, click Sun Cluster, then choose either Interactive Mode or Expert Mode. Follow the instructions in the PatchPro tool to describe your cluster configuration and download the patches.
    For third-party firmware patches, see the SunSolveSM Online site at http://sunsolve.ebay.sun.com.
  8. Install and configure Sun SDLM software on Node N, and apply required patches for Sun SDLM software support on Node N.
  9. Did you perform a reconfiguration reboot when you configured Sun SDLM software?
    • If yes, proceed to Step 10.
    • If no, perform a reconfiguration reboot to create the new Solaris device files and links on Node N.
      # boot -r
  10. On Node N, update the paths to the device ID instances.
    # scdidadm -C
    # scdidadm -r
  11. Return the resource groups and device groups that you identified in Step 1 to Node N.
    # scswitch -z -g resource-group -h nodename
    # scswitch -z -D device-group-name -h nodename
  12. On all remaining nodes and one node at a time, repeat Step 1 through Step 11.
ProcedureHow to Add Sun StorEdge Traffic Manager Software
The best way to enable multipathing for a cluster is to install the multipathing software and enable multipathing before installing the Sun Cluster software and establishing the cluster. For this procedure, see How to Install Sun Multipathing Software in Sun Cluster Software Installation Guide for Solaris OS. If you need to add multipathing software to an established cluster, use this procedure and be careful to perform the steps that clean up the device IDs.
Before You Begin
This procedure assumes that you have already installed and configured your storage array. If you have not installed your storage array, see How to Install Sun StorEdge Traffic Manager Software to add multipathing software and the storage array at the same time.
Steps
    Record this information because you use this information in Step 14 of this procedure to return resource groups and device groups to these nodes.
    # scstat
    Note –
    If you use multipathing software, each node requires two paths to the same set of LUNs. For an example configuration, see Figure 2–2.
    Note –
    For more information on how to boot nodes, see Sun Cluster system administration documentation.
  8. Install any required patches or software for Sun StorEdge Traffic Manager software support on Node N.
    For instructions on installing the software, see the Sun StorEdge Traffic Manager Installation and Configuration Guide at http://www.sun.com/products-n-solutions/hardware/docs/.
  9. (Optional) Activate multipathing functionality.
    • If you are using the Solaris 10 operating system, issue the following commands to enable multipathing:
      # /usr/sbin/stmsboot -e
      stmsboot -e
      Enables Solaris I/O multipathing
      See the stmsboot(1M) man page for more information.
    • If you are using the Solaris 8 or 9 operating system, edit the /kernel/drv/scsi_vhci.conf file.
      Set the mpxio-disable parameter to no.
      For more information, see the release notes for your storage device.
  10. Boot Node N into cluster mode.
    # boot -r
  11. On each node connected to the storage array, use the format(1M) command. Use this command to verify that the same set of LUNs is visible to the expected controllers.
    # format
  12. On Node N, configure all controllers that are affected by the new physical path.
    # cfgadm -c configure cN
  13. On Node N, update the paths to the device ID instances.
    # scdidadm -C
    # scdidadm -r
    scdidadm -C and -r
    Update DID mappings with new device names while preserving DID instance numbers for disks that are connected to multiple cluster nodes. DID instance numbers of the local disks might not be preserved. For this reason, the DID disk names for local disks might change.
  14. Return the resource groups and device groups that you identified in Step 1 to Node N.
  15. On each node connected to the storage array, use the format(1M) command. Use this command to verify that you see half the number of disks you saw in Step 11.
    # format
  16. On all remaining nodes and one node at a time, repeat Step 1 through Step 14.
