Sun Cluster 3.0 - 3.1 with StorageTek Fibre Channel RAID Arrays Manual for Solaris OS
How to Install Storage Arrays in a New Cluster
Use this procedure to install a storage array in a new cluster. To add a storage array to an existing cluster, use the procedure in How to Add Storage Arrays to an Existing Cluster.
This procedure relies on the following assumptions:
ProcedureInstall and Cable the Hardware
  1. Unpack, place, and level the storage array.
    For instructions, see the StorageTek online documentation listed in Table P–2.
  2. (Optional) Install the Fibre Channel (FC) switch for the storage array if you do not have a switch installed.
    For the procedure about how to install an FC switch, see the documentation that shipped with your FC switch hardware.
  3. Connect the nodes to the service processor panel.
    • (SAN Configuration) Connect the FC switches to the service processor panel.
    • (Direct-Attached Configuration) Connect each node to the service processor panel directly.
    For instructions, see the StorageTek documentation listed in Related Documentation.
  4. Install the storage array.
  5. Power on the storage array and the nodes.
  6. Configure the service processor.
ProcedureInstall the Solaris Operating System and Configure Multipathing
  1. On all nodes, install the Solaris operating system and apply the required Solaris patches for Sun Cluster software and storage array support.
    For the procedure about how to install the Solaris operating environment, see How to Install Solaris Software in Sun Cluster Software Installation Guide for Solaris OS.
  2. Install any required patches or software for Sun StorEdge Traffic Manager software support to nodes and enable multipathing.
    For the procedure about how to install the Sun StorEdge Traffic Manager software, see How to Install Sun Multipathing Software in Sun Cluster Software Installation Guide for Solaris OS.
See Also
