This procedure describes what data to collect when Directory Server is still running, but is no longer responding to client application requests.
Collect the data describe in this procedure while the server is hanging.
Note the time during which the hang is seen to occur.
Collect information about the port used during the hang.
netstat -an | grep ds-port
netstat -an
Collect statistics about the system running Directory Server.
ps -aux | grep server-root
vmstat 5 5
iostat -x
top
uptime
vmstat 5 5
iostat -x
top
sar
vmstat 5 5
top
uptime
sar
Get the process ID using the tlist.exe command, then get process details using the same command.
win-dbg-root\tlist.exe pid
Collect swap information.
swap -l
swapinfo
free
Already provided in C:\report.txt.
On Solaris systems, collect output from pstack and pmap five times, once every ten seconds.
pstack pid
pmap -x pid
Get output showing system calls during the hang, by letting each of the commands listed here run for about a minute, then stopping them by typing Control-C.
truss -ealf -rall -wall -vall -o /tmp/truss.out -p pid
tusc -v -fealT -rall -wall -o /tmp/truss.out -p pid
strace -fv -o /tmp/strace.out -p pid
Use Debug View.
DebugView is available at http://www.sysinternals.com/Utilities/DebugView.html.
Collect core files or crash dumps, and related command output.
When the server is hanging, attempt to get several core files that show the state of the server threads over time. You can do this by generating a core file, changing the name of the core file, waiting 30 seconds to a minute, and generating another core file. Repeat the process at least once to get a minimum of three sets of core files and related data.
cd server-root/bin/slapd/server
gcore -o /tmp/directory-core pid
pstack /tmp/directory-core
For each core file on Solaris OS, collect output from the following commands.
file core-file
pstack core-file
pmap core-file
pflags core-file
For at least one of the core files on Solaris OS, collect output from the pkg_app script.
./pkg_app.ksh pid /tmp/directory-core
Here, pid is the server process ID number. See To Run the pkg_app Script for instructions on using pkg_app.
If you have the patches PHKL_31876 and PHCO_32173 patches installed, generate the core file using the gcore command.
gcore -p pid
Otherwise, use the gdb command to generate the core file.
gdb
(gdb) attach pid
Attaching to process pid
No executable file name was specified
(gdb) dumpcore
Dumping core to the core file core.pid
(gdb) quit
The program is running. Quit anyway (and detach it)? (y or n) y
Detaching from program: , process pid
gdb
(gdb) attach pid
No executable file was specified
(gdb) gcore
Saved corefile core.pid
(gdb) backtrace
(gdb) quit
win-dbg-root\adplus.vbs -hang -p pid -o C:\dump-dir
Collect everything in the folder under C:\dump-dir.
Collect output from idsktune.
The idsktune command provides information on system parameters, patch level, tuning recommendations, and so forth. The command is described in the product documentation.
server-root/bin/slapd/server/idsktune
