The SUNWscpux 64–bit source compatibility package must be installed on systems that have more than 4 Gbytes of RAM before you can install Sun Management Center 4.0. If the package is not installed, the command-line installation process will report the following messages and fail.
ps: read() on /proc/551/as: Value too large for defined data type ps: read() on /proc/542/as: Value too large for defined data type |
The SUNWscpux package is installed automatically during Solaris installation when any of the following Solaris environments are selected.
Entire +OEM
Entire
Developer
To determine if the package is installed on the system, type the command pkginfo SUNWscpux in a terminal window.
If the package is installed, information about the package is displayed.
# pkginfo SUNWscpux system SUNWscpux Source Compatibility (Usr) (64-bit) |
If the package is not installed, an error message is displayed.
# pkginfo SUNWscpux ERROR: information for "SUNWscpux" was not found |
To install the SUNWscpux package:
Log in as root (su - root).
Locate the package on the Solaris installation media.
Install the package using the pkgadd command.
