Sun Management Center 4.0 Installation and Configuration Guide
ProcedureTo Set PATH on Microsoft Windows 2000
  1. Choose Start -> Settings -> Control Panel.
  2. Double-click System.
  3. Select the Advanced tab and then Environment Variables.
    The Environment Variables window is displayed.
  4. Click Path in the User Variables and System Variables and click Edit.
    The Edit System Variable window is displayed.
    Note –
    The Edit System Variable window shows the Microsoft Windows root directory using the environment variable %SystemRoot%.
  5. Add the location of the JDK bin directory to the PATH statement.
    For example, if the PATH statement shown in the Edit System Variable window is %SystemRoot%\system32;%SystemRoot%, the new path statement would then be %SystemRoot%\system32;%SystemRoot%;c:\j2version-number\bin where version-number is the JDK version.
    For example:
    %SystemRoot%\system32;%SystemRoot%;c:\j2sdk1.5\bin
    Separate each directory in the PATH statement with a semicolon as shown.
  6. Click OK to successively close each window.
