Solaris Common Desktop Environment: User's Guide
To Set the Play Rate for a File
  1. Place the cursor over the triangle on the lower left of the screen.
  2. Right-click the mouse button.
  3. From the pull-down menu select one of the options.
    • 1/10 speed - 1/10th the original rate
    • Half speed - 1/2 the original rate
    • Normal speed - the original rate
    • Double speed - twice the original rate
    • Triple speed - three times the original rate
    • Quadruple speed - four times the original rate
