Solaris Common Desktop Environment: User's Guide
Leaving the Desktop
This section describes how to log out of and exit the desktop, and how to lock your display to prevent unauthorized use of your system when you are away from it and have not logged out.
To Log Out
Caution – Caution –
Before logging out of the desktop, save your work in all open application windows. Remember to check each workspace.
    Click the Exit control in the Front Panel.
    Graphic
    Or, choose Log out from the Workspace menu.
    Note –
    You cannot display the Workspace menu using your keyboard.
As you log out of the desktop, your current session is saved. When you log back in, the desktop will appear as it did before you logged out.
Applications that do not get saved as part of the current session include:
To Lock Your Display
To prevent unauthorized use of your system when you are away from it and have not logged out:
    Click the Lock control in the Front Panel.
    Graphic
To unlock your display, type your password.
For information about screen lock options, refer to Chapter 9, Customizing the Desktop Environment.
