If you are using the standard ISO 8859-1 (Latin-1) code set you can produce all characters by pressing the Compose key followed by other keys. These compose key sequences are listed in Table C–1.
ISO Latin-1 does not support the character for the Euro currency symbol (see Euro Currency Symbol).
On a SPARC keyboard, pressing the Compose key should illuminate the light on the key. On an IA keyboard, the Compose key is Control-Shift-F1 (hold the Control and Shift keys down and press the F1 key).
Table C–1 Compose Key Sequences for ISO Latin-1 Code Set
Compose |
Result |
Description |
space |
space |
Space |
Inverted exclamation |
c |
Cents |
l |
Pounds sterling |
o |
x |
Currency symbol |
y |
Yen |
Broken bar |
s |
o |
Section |
Umlaut/diaeresis |
c |
o |
Copyright |
a |
ª |
Feminine ordinal |
Left guillemet |
Not sign |
Soft hyphen |
r |
o |
Registered |
Macron |
0 |
Degree |
Plus-minus |
2 |
² |
Superscript 2 |
3 |
³ |
Superscript 3 |
Prime/acute accent |
u |
µ |
Mu/micro |
P |
Pilcro/paragraph |
Middle dot |
Cedilla |
1 |
¹ |
Superscript 1 |
_ |
o |
º |
Masculine ordinal |
Right guillemet |
1 |
4 |
¼ |
Quarter |
1 |
2 |
½ |
Half |
3 |
4 |
¾ |
Three quarters |
Inverted question |
A |
À |
A grave |
A |
Á |
A acute |
A |
A circumflex |
A |
à |
A tilde |
A |
Ä |
A umlaut |
A |
Å |
A angstrom |
A |
E |
Æ |
AE ligature |
C |
Ç |
C cedilla |
E |
È |
E grave |
E |
É |
E acute |
E |
Ê |
E circumflex |
E |
Ë |
E umlaut |
I |
Ì |
I grave |
I |
Í |
I acute |
I |
Î |
I circumflex |
I |
Ï |
I umlaut |
D |
Ð |
Eth |
N |
Ñ |
N tilde |
O |
Ò |
O grave |
O |
Ó |
O acute |
O |
Ô |
O circumflex |
O |
Õ |
O tilde |
O |
Ö |
O umlaut |
x |
x |
x |
Multiply |
O |
Ø |
O slash |
U |
Ù |
U grave |
U |
Ú |
U acute |
U |
Û |
U circumflex |
U |
Ü |
U umlaut |
Y |
Ý |
Y acute |
T |
H |
Þ |
Thorn |
s |
s |
ß |
Eszett/digraph s |
a |
à |
a grave |
a |
á |
a acute |
a |
â |
a circumflex |
a |
ã |
a tilde |
a |
ä |
a umlaut |
a |
å |
a angstrom |
a |
e |
æ |
ae ligature |
c |
ç |
c cedilla |
e |
è |
e grave |
e |
é |
e acute |
e |
ê |
e circumflex |
e |
ë |
e umlaut |
i |
ì |
i grave |
i |
í |
i acute |
i |
î |
i circumflex |
i |
ï |
i umlaut |
d |
ð |
eth |
n |
ñ |
n tilde |
o |
ò |
o grave |
o |
ó |
o acute |
o |
ô |
o circumflex |
o |
õ |
o tilde |
o |
ö |
o umlaut |
Divide |
o |
ø |
o slash |
u |
ù |
u grave |
u |
ú |
u acute |
u |
û |
u circumflex |
u |
ü |
u umlaut |
y |
ý |
y acute |
t |
h |
þ |
thorn |
y |
ÿ |
y umlaut |
Localized keyboards do not all generate the same key codes for ISO Latin-1 characters. However, system translation tables take care of producing the right character code. The SunOS system finds its tables in /usr/share/lib/keytables.
