Solaris Common Desktop Environment: User's Guide
Window List Options
There are two options that you can change using the Window List – Options dialog box:
These two options allow the setting of which columns will appear in the Window List and what action will be taken when you double-click on a window item in the Window List.
Figure 7–8 Window List – Options Dialog
Graphic
To Show Columns
  1. Click the State, Application, or Workspace check boxes for that column to be displayed.
    The lack of a checkmark means the column will not be displayed.
    Note –
    The Window Title column will always be visible.
To Set the Action of a Double-click on a Window Entry
Window List provides the ability to select the effect of double-clicking a window entry in the Window List.
  1. Click the Switches to the workspace where the window resides check box.
    This has the effect of switching to the workspace that contains the selected window.
  2. Click the Moves the window to the current workspace check box.
    This has the effect of moving the selected window to the current workspace.
