Pencil
For drawing freehand
lines and individual pixels.
Press and hold to draw freehand lines.
Line
For drawing straight
lines.
Press and hold to stretch the line. Release to draw the line.
Rectangle
For drawing solid
or outlined rectangles.
Press and hold to stretch the outline of the rectangle.
Release to draw the rectangle.
Circle
For drawing solid
or outlined circles.
Point to where you want the center of the circle, press and hold, drag to
the desired size, and release.
Eraser
For erasing large
areas of the image.
Press and hold; then drag over the area to erase.
To erase individual
pixels, select the Pencil tool and the Transparent color.
Flood
For flooding a region
of one color with the selected color.
Click any pixel within the region to be flooded.
The selected pixel and all adjacent pixels of the same color are recolored
with the selected color. The filled region extends in all directions, bounded
only by pixels of a different color.
Open Polygon
For
drawing connected straight lines.
Click the starting point; then click for each segment.
Double-click to end the last segment.
Closed Polygon
For
drawing connected straight lines, where the first line and last line are connected
to form a closed polygon.
Ellipse
For drawing solid
or outlined ovals.
Press and hold, drag to the desired size and shape, and release.
Selection
For selecting an
area to work on. Several commands in the Edit menu require an area to be selected.
Point
to the corner pixel of the region to be selected, press and hold, drag to
the desired region, and release.
Fill Solids
For
changing the rectangle, circle, ellipse, and closed polygon tools to draw
filled-in shapes instead of outlines.
Select the check
box to automatically draw filled-in shapes. Deselect the check box to return
the tools to drawing outlines.
