Solaris Common Desktop Environment: User's Guide
To Select a List Item
Some windows and dialog boxes display lists from which you select options or settings.
  1. Press Tab to move the highlight to the list.
  2. Press the arrow keys to move through the list.
    To select more then one contiguous item in lists that allow you to do so, press Shift+Down Arrow or Shift+Up Arrow.
  3. Press Tab to move the highlight to the appropriate button (such as OK), then press Return.
