You can select and copy one or more of the process entries in the display, and paste the text into other applications.
You also have the following options for saving the sample data to files:
Creating a new file containing only the current sample
Setting up a log file to which each new sample is appended
Choose Save As from the Sample Menu.
Process Manager displays the Save As dialog box.
Specify the name and location of a new file and click OK.
Process Manager creates the text file containing the process entries from the current display.
Choose Log File from the Sample menu.
Process Manager displays the Log File dialog box.
Process Manager creates the text file and appends each new sample (with header information) to the file.
Process Manager will continue to append to this file until you terminate the Process Manager application, or until you choose Stop Logging from the Sample menu.
