Solaris Common Desktop Environment: User's Guide
To Move Text (Cut and Paste)
  1. Select the text.
  2. Choose Cut from the Edit menu or press Control+X.
    The text is erased from the document and stored on a clipboard where it can be accessed or replaced by other applications.
  3. Move the cursor to where you want to insert the text.
  4. Choose Paste from the Edit menu or press Control+V.
    You can also use drag and drop to move text (see To Move Text Using Drag and Drop).
