Solaris Common Desktop Environment: User's Guide
Text Editor and Other Applications
Other applications can use Text Editor as a tool to edit documents or other types of information. Under certain conditions, an application may choose to restrict your editing choices. In the example below, the File menu has been modified. The Save As command has been replaced with a Copy To File command and the New and Open commands are not available.
Figure 12–15 Text Editor with modified File menu
Graphic
