The dhcpmgr tool provides an interface, com/sun/dhcpmgr/client/DSModule, which defines the API functions that the public module management bean must implement.
The DSModule interface is contained in the dhcpmgr.jar file. In order to compile the bean against this interface, you must add /usr/sadm/admin/dhcpmgr/dhcpmgr.jar to the javac class path. For example, for your bean named myModule.java, type
javac -classpath /usr/sadm/admin/dhcpmgr/dhcpmgr.jar myModule.java
abstract java.awt.Component getComponent()
Returns a component that is displayed as one of the wizard steps for the DHCP Configuration Wizard. The returned component should be a panel containing GUI components to be used to obtain data-store-specific data from the user during configuration. The configuration data itself will be returned to the wizard as a result of calls to the getPath() and getAdditional() methods. See getPath() and getAdditional() for more information.
abstract java.lang.String getDescription()
Returns a description that is used by the DHCP Configuration Wizard when it adds the data store to the list of data store selections. For example, the management bean for the ds_SUNWfiles.so public module returns “Text files” as the description.
abstract java.lang.String getPath()
Returns the path/location that is used by the data store (the PATH value in the Framework Configuration Layer configuration file /etc/inet/dhcpsvc.conf), or null if not set. The path/location value should be supplied by the user by interaction with the management bean's component. See Passing Data Store Configuration Data.
abstract java.lang.String getAdditional()
Returns additional data-store-specific information, such as the RESOURCE_CONFIG value in the Framework Configuration Layer configuration file /etc/inet/dhcpsvc.conf. The value returned by this method is most likely supplied by the user by interaction with the management bean's component. See Passing Data Store Configuration Data.
