Solaris Common Desktop Environment: Advanced User's and System Administrator's Guide
Setting a Value for DTMOUNTPOINT
You must set the DTMOUNTPOINT environment variable if both of the following conditions are true:
  1. Edit the file /etc/inetd.conf:
  2. Find the dtspcd entry and add:
    		-mount_point mount_point
  3. Find the rpc.ttdbserver entry and add:
    		-m mount_point
    For example if the automounter is being used with a mount point of /nfs, the entries in /etc/inetd.conf are:
    	dtspc stream tcp nowait root /usr/dt/bin/dtspcd \
     	/usr/dt/bin/dtspcd -mount_point /nfs
     	rpc stream tcp wait root /usr/dt/bin/rpc.ttdbserver \
     	100083 1 rpc.ttdbserver -m /nfs
  4. Perform the procedure on your system that rereads /etc/inetd.conf. For more information, see the inetd(1M) man page.
  5. Set DTMOUNTPOINT such that its value is inherited by user logins.
    This can be done by setting the variable in /etc/dt/config/Xsession.d. For more information on setting environment variables, see To Set Environment Variables.
