Solaris Common Desktop Environment: Advanced User's and System Administrator's Guide
To Set a System-Wide Application Search Path
  1. Log in as root.
  2. If the file /etc/dt/config/Xsession.d/0010.dtpaths doesn't exist, create it by copying /usr/dt/config/Xsession.d/0010.dtpaths.
  3. Open /etc/dt/Xsession.d/0010.paths for editing. Add or edit a line that sets and exports the DTSPSYSAPPHOSTS variable:
    	export DTSPSYSAPPHOSTS=hostname:[,hostname]
    For example, the following line adds the system ApServA to the application search path:
    	export DTSPSYSAPPHOSTS=ApServA:
  4. Inform all users on the system that they must log out and then log back in for the change to take effect.
