Solaris Common Desktop Environment: Advanced User's and System Administrator's Guide
Changing the Text Editor and Terminal Emulator
Both the text editor and terminal emulator applications can be started by choosing a control in the Front Panel, or by double-clicking an icon in Application Manager.
These applications are also started by other desktop activities.
You can configure the desktop to use a different text editor or terminal emulator application in these situations.
To Change the Default Text Editor or Terminal Emulator
  1. If the change is system-wide, log in as root.
  2. Create an action for the new text editor or terminal emulator application.
    Figure 4–3 Create Action window
    Graphic
    • Or, you can create the action definition manually; for example:.
    ACTION TextPad
            LABEL                TextPad
            TYPE                 COMMAND
            WINDOW_TYPE          NO_STDIO
            EXEC_STRING          /usr/TP/bin/TextPad %(File)Arg_1%
            DESCRIPTION          Double-click this icon to start the \
                TextPad application.
    For information on creating action definitions manually, see Chapter 12, Creating Actions Manually.
  3. Place the configuration file containing the new action in the proper directory:
    • System-wide: /etc/dt/appconfig/types/language
    • Personal: HomeDirectory/.dt/types
  4. If it doesn't already exist, create the appropriate user-prefs.dt file by copying /usr/dt/appconfig/types/language/user-prefs.dt to:
    • System-wide: the /etc/dt/appconfig/types/language directory
    • Personal: the HomeDirectory/.dt/types directory
  5. Edit the TextEditor or Terminal action in the system-wide or personal user-prefs.dt file. Modify the MAP_ACTION line to map the action to the new action.
    For example, change the line:
    	MAP_ACTION Dtpad
    to:
    	MAP_ACTION TxtPd
  6. Save the user-prefs.dt file.
  7. Double-click Reload Actions in the Desktop_Tools application group to reload the actions database.
