Solaris Common Desktop Environment: Advanced User's and System Administrator's Guide
Reasons You Must Create an Action Manually
There are three basic types of actions:
The Create Action tool is designed to create certain types of COMMAND and MAP actions. All TT_MSG actions must be created manually.
For more information, see Limitations of Create Action.
COMMAND Actions
A command action executes a command that starts an application or utility, runs a shell script, or executes an operating system command. The definition of the action includes the command to be executed (the EXEC_STRING).
The Create Action tool can be used to create the most common types of command actions. However, there may be some situations where you must create the action manually; for example, you must create a COMMAND action manually if the action specifies:
MAP Actions
A map action is an action that is ``mapped'' to another action rather than directly specifying a command or ToolTalk message
Mapping provides the ability to specify alternative names for actions. For example, a built-in command action named IconEditor starts Icon Editor. The database also includes an Open action, restricted in the definition to bitmap and pixmap files (by the ARG_TYPE field), that is mapped to the IconEditor action. This lets the user start Icon Editor by selecting a bitmap or pixmap file in File Manager and then choosing Open from the Selected menu.
Create Action provides limited mapping for Open and Print actions. All other map actions must be created manually.
TT_MSG (ToolTalk Message) Actions
TT_MSG actions send a ToolTalk message. All TT_MSG actions must be created manually.
