Solaris Common Desktop Environment: Advanced User's and System Administrator's Guide
Specifying the Window Support for the Action
Use the WINDOW_TYPE field to specify the type of windowing support required by the action as shown in Table 12–2.
Table 12–2 WINDOW_TYPE Field and Windowing Support Provided
WINDOW_TYPE
NO_STDIO
None. Use NO_STDIO if the application has its own window, or if the command has no visible output.
PERM_TERMINAL
Permanent terminal emulator window. The action opens a terminal window that remains open until the user explicitly closes it. The user can enter data into the window. Use with commands that take some input, produce some output, then terminate (for example, ls directory).
TERMINAL
Temporary terminal emulator window. The action opens a terminal window that closes as soon as the command is completed. Use with full-screen commands (for example, vi).
