Solaris Common Desktop Environment: Advanced User's and System Administrator's Guide
To Modify an Existing Action Definition
You can modify any of the actions available on your system, including built-in actions.
Note –
Use caution when modifying the built-in action database. The built-in actions are designed to work well with the desktop applications.
  1. Locate the definition of the action you want to modify.
    The default locations for action definitions are:
    • Built-in actions: /usr/dt/appconfig/types/language
    • System-wide actions: /etc/dt/appconfig/types/language
    • Personal actions: HomeDirectory/.dt/types
      Your system might include additional locations. To see a list of the locations your system uses for actions, type the command:
      	dtsearchpath -v
      Your system uses the directories listed under DTDATABASESEARCHPATH.
  2. If necessary, copy the text of the action definition to a new or existing file in one of these directories:
      You must copy built-in actions, since you should not edit files in the /usr/dt/appconfig/types/language directory.
  3. Edit the action definition.
  4. When you are done editing, save the file.
  5. Double-click Reload Actions in the Desktop_Tools application group.
