Solaris Common Desktop Environment: Advanced User's and System Administrator's Guide
Name or Absolute Path of the Executable
If your application is located in a directory listed in the PATH variable, you can use the simple executable name. If the application is elsewhere, you must use the absolute path to the executable file.
