Use one of the following syntax conventions:
If you want the action to prompt for the file names, use this syntax for each file argument:
%(File)"prompt"%
Use a different prompt string for each argument.
For example, this execution string prompts for two files.
EXEC_STRING xsetroot -cursor %(File)"Cursor bitmap:"% \ %(File)"Mask bitmap:"%
