Solaris Common Desktop Environment: Advanced User's and System Administrator's Guide
Chapter 13 Creating Data Types Manually
There are two ways to create a data type definition:
Creating a data type manually requires you to edit a database file.
This chapter describes how to manually create data type definitions.
Reasons You Must Create a Data Type Manually
Manually creating a data type lets you use all the capabilities built into the syntax of data type definitions.
You must create an data type manually if you want to use these features of data types:
Components of a Data Type Definition: Criteria and Attributes
A data type definition consists of two separate database definitions:
There must be at least one DATA_CRITERIA definition for each DATA_ATTRIBUTES definition; a DATA_ATTRIBUTES definition can have multiple DATA_CRITERIA associated with it.
For example, you could create an attributes definition for PostScript files that described how PostScript files look and behave in File Manager. Then, you could create two separate criteria for the PostScript data type— one based on file name and the other based on file content.
For more information, see Defining the Data Criteria for a Data Type.
Creating a Data Type Manually: General Steps
This section describes how to create a data type configuration file.
Configuration Files for Data Types
The requirements for configuration files containing data type definitions are:
To Create a Data Type Definition
  1. Open an existing database file or create a new one.
    For more information, see the previous section, Configuration Files for Data Types.
  2. Define the data attributes for the data type using the syntax:
    	DATA_ATTRIBUTES data_type_name
     		ICON						image_name
     		DESCRIPTION				string
     		attribute_field
     		attribute_field
    where:
    data_type_name—a unique name given to this data type.
    image_name—file name or path of an icon file. Use the base name for the file. For example, for icon files myimage.m.pm and myimage.t.pm, use myimage.
    attribute_field—field that defines the appearance or behavior of the data type.
    string—character string. The contents will be the on-item help for the data type.
    See Example of Creating a Personal Action and Data Type.
  3. Define the data criteria for the data type using the syntax:
    	DATA_CRITERIA criteria_name
     		DATA_ATTRIBUTES_NAME						data_type_name
     		criteria_field
     		criteria_field
    where:
    criteria_name—unique name for this criteria definition
    data_type_name—name used in the DATA_ATTRIBUTES definition
    criteria_field—field used to define the criteria for assigning a file to this data type
    See Defining the Data Criteria for a Data Type.
  4. Save the database file.
  5. Create the icons for the data type.
    For more information, see Specifying the Icon Image Used for a Data Type.
  6. If necessary, create the actions listed in the ACTIONS field of the attributes definition.
  7. Double-click Reload Actions in the Desktop_Tools application group to reload the database.
Suppose your system contains an application named xgif, which displays GIF pictures. Ordinarily, you run the program by executing:
xgif filename
You want to be able to display GIF pictures several ways:
  1. Open a new file HomeDirectory/.dt/types/GifViewer.dt for editing.
  2. Type the data type definitions:
    	DATA_ATTRIBUTES Gif
     		DESCRIPTION				Gif image file.
     		ICON						GifIcon
     		ACTIONS					View
     	DATA_CRITERIA Gif_Criteria
     		DATA_ATTRIBUTES_NAME			Gif
  3. Type the action definition for the GifViewer action:
    	ACTION GifViewer
     		EXEC_STRING					xgif %(File)Arg_1"Gif file to view:"
     		WINDOW_TYPE					NO_STDIO
     		DESCRIPTION					Double-click or drop a file to \
     										start the Gif viewer.
    Since the definition does not include an ICON field, the action will use the system's default icon.
  4. Type the following map action to connect the GifViewer action to the View action listed in the data type definition. Use the ARG_TYPE field to restrict this view action to Gif-type files.
    	ACTION View
     		ARG_TYPE				Gif
     		TYPE					MAP
     		MAP_ACTION			GifViewer
  5. Save the file.
  6. Double-click Reload Actions in the Desktop_Tools application group to reread the database.
Defining the Data Attributes of a Data Type
The DATA_ATTRIBUTES definition defines the appearance and behavior of the data type. It specifies the name of the data type, and provides the ability to specify:
Use the ICON field to specify the icon used in File Manager. If you do not specify an icon image, File Manager displays only a label.
The value of the ICON field can be:
Table 13–1 Icon Names and Sizes for Data Type Icons
Size in Pixels
Bitmap Name
Pixmap Name
32 by 32
name.m.bm
name.m.pm
16 by 16
name.t.bm
name.t.pm
Associating Data Types with Actions
There are two ways that data types are associated with actions:
Hiding Files Based on Data Type
If a file is an invisible data type, it never appears in File Manager.
Use the PROPERTIES field in the DATA_ATTRIBUTES definition to specify that objects of this type be hidden:
PROPERTIES				invisible
Specifying Behaviors When the File Is Manipulated
Table 13–2 shows the DATA_ATTRIBUTES fields that are used primarily by application programmers. They specify how files behave when the user performs various desktop activities.
For more information, see the Common Desktop Environment Programmer's Guide, which is part of the developer environment documentation.
Table 13–2 DATA_ATTRIBUTES Fields and Descriptions
Field
Description
MOVE_TO_ACTION
For containers such as directories. Specifies an action to be run when a file is moved to a container of this data type.
COPY_TO_ACTION
For containers such as directories. Specifies an action to be run when a file is copied to a container of this data type.
LINK_TO_ACTION
Specifies an action to be run when a file is linked to a file of this data type.
IS_TEXT
Specifies that files of this data type contain text that can be displayed in a text box.
MEDIA
Specifies the corresponding ToolTalk media type.
MIME_TYPE
Specifies the corresponding MIME type.
X400_TYPE
Specifies the corresponding X400 type.
The DATA_CRITERIA definition defines the criteria used to assign an object type to a file or directory.
You can use the criteria show in Table 13–3 for object typing.
Table 13–3 DATA_CRITERIA Criteria and Descriptions
Criteria
Description
File name
The file name must match a specified pattern. Use the NAME_PATTERN field.
File location
The path must match a specified pattern. Use the PATH_PATTERN field.
File contents
A specified portion of the file's contents must match specified data. Use the CONTENT field.
File mode
The file must possess the specified permissions (read, write, execute, directory). Use the MODE field.
Symbolic links
The typing is based on the file to which the object is linked.
You can use more than one criteria for a data type. However, you should not use the NAME_PATTERN and PATH_PATTERN criteria in the same data type.
Name-Based Data Types
Use the NAME_PATTERN field to specify the naming requirement. The field value can include the following wildcards:
?—matches any single character
*—matches any sequence of characters (including a null string)
[cc]—matches any of the characters (c) enclosed in brackets
[cc]—matches any of the characters in the range c through c
Examples
Location-Based Data Types
Use the PATH_PATTERN field to specify the path. You can use the same wildcard characters as with NAME_PATTERN.
For example, the following data type uses a criteria based on path.
DATA_ATTRIBUTES Project_Graphics
     DESCRIPTION       Graphics file for the QS project. Double-click the \
                       icon to see the graphic.
 ICON                  QSgraphics
 DATA_CRITERIA Project_Graphics_Criteria
 DATA_ATTRIBUTES_NAME  Project_Graphics
 PATH_PATTERN          */projects/QS/graphics/*
Data Types Based on Name and Location
To create a data type based on both file name and location, include the name in the PATH_PATTERN value. You cannot use both NAME_PATTERN and PATH_PATTERN in the same criteria definition.
Examples
Using File Modes as a Typing Criteria
Use the MODE field to specify the required permissions.
Mode criteria are usually used in combination with name-based, location-based, or content-based data typing. They allow you to limit a data type to a file or directory, or to specify the required read, write, and execute permissions.
The MODE field can include logical operators (Table 13–4) and characters (Table 13–5).
Table 13–4 MODE Field Logical Operators and Descriptions
Operator
Description
Logical operator NOT
Logical operator AND
Logical OR
Table 13–5 MODE Field Characters and Descriptions
Character
Description
f
The data type applies only to files
d
The data type applies only to directories
r
The file is readable by any user
w
The file is writable by any user
x
The file is executable by any user
l
The file is a link
The default for a particular mode is that the mode does not matter.
Examples
Content-Based Data Typing
Use the CONTENT field to specify data typing based on the content of the file. Content-based data typing can be used in combination with name- or location-based data typing.
The typing can be based on either string or numeric content for files. The first byte in the file is numbered 0.
To Create a Data Type with Several Independent Criteria
You can create a data type with several independent criteria—that is, the file is assigned to the data type if it meets either (or both) of the criteria.
  1. Create the DATA_ATTRIBUTES definition for the data type.
  2. Create a DATA_CRITERIA definition for each criteria.
    Use the DATA_ATTRIBUTES_NAME field to connect each criteria to the same DATA_ATTRIBUTES definition.
    For example, the following definitions create the Mif data type. Typing is based on name or content.
    DATA_ATTRIBUTES Mif
     	ICON								Frame
     	ACTION_LIST						Open,Print
     DATA_CRITERIA Mif_Name_Criteria
     	DATA_ATTRIBUTES_NAME				Mif
     	NAME_PATTERN							*.mif
     DATA_CRITERIA Mif_Content_Criteria
     	CONTENT							1 string MIFFile
Creating Localized Data Types
The search path for data types includes language-dependent locations. The desktop uses the value of LANG to determine the locations searched for data type definitions.
Locations for Localized Data Types
Localized data type definitions must be placed in the proper language-dependent directories along the actions search path.
The default search path is:
To Localize a Data Type
  1. Create a file in the appropriate language-dependent directory (for example, in /etc/dt/appconfig/types/japanese) .
  2. Copy the data type definition to the language-dependent configuration file.
  3. Localize one or more fields in the data type definition.
