Solaris Common Desktop Environment: Advanced User's and System Administrator's Guide
Specifying Behaviors When the File Is Manipulated
Table 13–2 shows the DATA_ATTRIBUTES fields that are used primarily by application programmers. They specify how files behave when the user performs various desktop activities.
For more information, see the Common Desktop Environment Programmer's Guide, which is part of the developer environment documentation.
Table 13–2 DATA_ATTRIBUTES Fields and Descriptions
Field
Description
MOVE_TO_ACTION
For containers such as directories. Specifies an action to be run when a file is moved to a container of this data type.
COPY_TO_ACTION
For containers such as directories. Specifies an action to be run when a file is copied to a container of this data type.
LINK_TO_ACTION
Specifies an action to be run when a file is linked to a file of this data type.
IS_TEXT
Specifies that files of this data type contain text that can be displayed in a text box.
MEDIA
Specifies the corresponding ToolTalk media type.
MIME_TYPE
Specifies the corresponding MIME type.
X400_TYPE
Specifies the corresponding X400 type.
