Solaris Common Desktop Environment: Advanced User's and System Administrator's Guide
Using the Find Set Dialog Box To Specify an Icon
The Find Set dialog box is displayed when you click Find Set in the Create Action main window or in the Add Datatype window. Use the dialog box to specify the icon that will be used for the action or data type.
Figure 11–10 Find Set dialog box
Graphic
The Find Set dialog box lets you specify a set of icon image files located:
To Specify a Set of Icons Located on the Icon Search Path
  1. In the Find Set dialog box's Icon Folders list, double-click the folder path containing the icon.
    The Icon Files list will show all the icon files in that folder.
  2. In the Icon Files list, click the icon you want to use.
    This places the base name of the icon file in the Enter Icon File name text field.
  3. Click OK.
To Specify an Icon in a Registration Package
If you are a system administrator or programmer creating a registration package, the icon image files are initially located in a directory in the registration package:
app_root/dt/appconfig/icons/language
After registration with dtappintegrate, the icon files will be copied to /etc/dt/appconfig/icons/language, which is on the icon search path.
Use this procedure to specify icons that are part of a registration package:
  1. In the Find Set dialog box's Enter Icon Filename text field, type the base name of the icon file.
  2. Click OK.
    Create Action displays a dialog box to inform you that the icons were not found in directories on the icon search path.
  3. In the information dialog box that appears, choose No Change.
