Solaris Common Desktop Environment: Advanced User's and System Administrator's Guide
To Specify an Icon in a Registration Package
If you are a system administrator or programmer creating a registration package, the icon image files are initially located in a directory in the registration package:
app_root/dt/appconfig/icons/language
After registration with dtappintegrate, the icon files will be copied to /etc/dt/appconfig/icons/language, which is on the icon search path.
Use this procedure to specify icons that are part of a registration package:
  1. In the Find Set dialog box's Enter Icon Filename text field, type the base name of the icon file.
  2. Click OK.
    Create Action displays a dialog box to inform you that the icons were not found in directories on the icon search path.
  3. In the information dialog box that appears, choose No Change.
