Solaris Common Desktop Environment: Advanced User's and System Administrator's Guide
Modifying the Main Panel
The Main Panel is the Front Panel window, excluding the subpanels.
Figure 15–2 Main Panel containers
Graphic
Modifications you can make include:
To Add a Control to the Main Panel
  1. Create a Front Panel configuration file:
    • System-wide: /etc/dt/appconfig/types/language/*.fp
    • Personal: HomeDirectory/.dt/types/*.fp
  2. Define the control in the file.
    Use the CONTAINER_NAME and CONTAINER_TYPE fields to specify the container for the control:
    CONTAINER_NAME  Top
     	CONTAINER_TYPE  BOX
    Use POSITION_HINTS to specify the left-to-right placement of the control. Since customizations have precedence over built-in controls, the new control will “bump” the existing control with that position one position to the right.
  3. Save the configuration file.
  4. Create an icon for the Front Panel control.
    See Specifying the Icon Used by a Control.
  5. Choose Restart Workspace Manager from the Workspace menu.
    For example, the following control definition placed in the file /etc/dt/appconfig/types/language/audio.fp inserts an audio application control between the Clock and Calendar controls.
    CONTROL AudioApplication
      TYPE             icon
      CONTAINER_NAME   Top
      CONTAINER_TYPE   BOX
      ICON             AudioApp
      POSITION_HINTS   2
      PUSH_ACTION      StartAudioApplication
      PUSH_RECALL      true
To Remove a Control
    • System-wide: /etc/dt/appconfig/types/language/name.fp
    • Personal: HomeDirectory/.dt/types/name.fp
  2. Copy the definition of the control you want to delete to the new file.
    If the control is built-in, its definition is in /usr/dt/appconfig/types/language/dtwm.fp.
    You do not need to copy the entire definition. However, the portion you copy must include the fields CONTAINER_NAME and CONTAINER_TYPE.
  3. Add the DELETE field to the definition:
    	DELETE			True
  4. Save the configuration file
    For example, the following control definition placed in the file /etc/dt/appconfig/types/language/TrashCan.fp removes the Trash Can control from the Front Panel.
    CONTROL Trash
      CONTAINER_NAME  Top
      CONTAINER_TYPE  BOX
      DELETE          True
To Modify a Control
Use this procedure when you need to modify a control definition—for example, to change its icon image.
  1. Copy the entire control definition from /usr/dt/appconfig/types/language/dtwm.fp to:
    • Personal: HomeDirectory/.dt/types/name.fp.
  2. Edit the field you want to change. You can also add additional fields.
  3. Save the file
  4. Choose Restart Workspace Manager from the Workspace menu.
To Interchange the Position of Controls
  1. Copy the control definitions for the controls whose positions you want to change from /usr/dt/appconfig/types/language/dtwm.fp to:
      You must copy the entire control definition for each control to be moved.
  2. Interchange the values of the POSITION_HINTS fields of the control definitions.
  3. Save the file
    For example, the following definitions placed in a file /etc/dt/appconfig/types/C/MailHelp.fp interchange the positions of the Mail and Help Manager controls and lock these controls against personal changes.
    CONTROL Mail
     	POSITION_HINTS					12
     	LOCKED							True
     	…the rest of the control definition
    CONTROL Help
     	POSITION_HINTS					5
     	LOCKED							True
To Replace a Front Panel Control
    Create another control definition with the same:
The control definition's ICON field defines the icon image used for the control.
The value of the ICON field can be:
