Solaris Common Desktop Environment: Advanced User's and System Administrator's Guide
Customizing the Workspace Switch
There are several ways to customize the workspace switch:
To Change the Default Number of Workspaces
    Modify the following Workspace Manager resource:
	Dtwm*workspaceCount:						n
For more information, see To Change the Number of Workspaces on a System-Wide Basis.
To Change the Number of Switch Rows
    Modify the NUMBER_OF_ROWS field in the SWITCH definition.
For example, the following definition defines a three-row switch.
SWITCH Switch
 	CONTAINER_NAME				box_name
 	NUMBER_OF_ROWS				3
To Change or Add Controls in the Workspace Switch
  1. Create a Front Panel configuration file with the control definition.
    • Specify that the control be inside the switch:
      		CONTAINER_NAME   Switch
       		CONTAINER_TYPE   SWITCH
    • Specify the position in the switch:
      		POSITION_HINTS    n
      where n is an integer. The positions are numbered sequentially left-to-right, top-to-bottom. (For the default two-row switch, the positions are 1 through 4.)
  2. Create the icon for the control. The recommended size is 16 by 16 pixels.
    For example, the following control puts a Terminal control in the switch.
    		CONTROL SwitchTerminal
    	TYPE                  icon
    	POSITION_HINTS        3
    	ICON                  Fpterm
    	LABEL                 Terminal
    	PUSH_ACTION           Dtterm
    	HELP_TOPIC            FPOnItemTerm
    	HELP_VOLUME           FPanel
    The control uses a built-in icon and the same help topic used by the Terminal control in the Personal Applications subpanel.
