Solaris Common Desktop Environment: Advanced User's and System Administrator's Guide
To Change the Auto-Close Behavior of Subpanels
The default behavior of subpanels is to close when the user chooses a control, unless the user has moved the subpanel from its original position.
The Front Panel can be configured to keep subpanels open until the user explicitly closes them.
  1. Create a new Front Panel configuration file in:
    • System-wide: /etc/dt/appconfig/types/language/*.fp
    • Personal: HomeDirectory/.dt/types/*.fp
  2. Copy the default PANEL definition from /usr/dt/appconfig/types/language/dtwm.fp to the new file:
    	PANEL FrontPanel
  3. Add the following field to the PANEL definition:
    	SUBPANEL_UNPOST    False
  4. Save the new configuration file.
  5. Choose Restart Workspace Manager from the Workspace menu.
