Use these fields to define the control's behavior:
TYPE: Specify one of the following values:
icon—use this type if you want to specify a PUSH_ACTION and/or DROP_ACTION for the control.
file—use this type if you want the control, when chosen, to behave like the file when the file's icon is double-clicked in File Manager.
ICON and ALTERNATE_ICON: Describe the images used to indicate the non-changed and changed state of the monitored file.
MONITOR_TYPE: Describes the conditions causing the image to change. Use one of the following values:
mail—the control will change appearance when information is added to the file.
file—the control will change when the specified file becomes non-empty.
FILE_NAME: Specifies the file to be monitored.
For example, the following control looks for the presence of a file named meetings that you expect to be transferred to your system using anonymous ftp. The control is placed at the top of the Personal Applications subpanel.
CONTROL MonitorCalendar { TYPE file CONTAINER_NAME PersonalApps CONTAINER_TYPE SUBPANEL POSITION_HINTS first FILE_NAME /users/ftp/meetings MONITOR_TYPE file ICON meetingsno ALTERNATE_ICON meetingsyes }
