Any Xterminal that supports the XDM protocol can use Chooser to log in to Solaris CDE. To run the Chooser, refer to the section Using Workstations as XTerminals. The SPARC XterminalTM software version 2.0 (or later) works well with Solaris CDE. Click Properties on the X-Terminal Controls window and choose Session as the Category to display the setup screen shown in Figure 6–2.
Select None for the Local Window Manager, and XDM Indirect for the XDM connection to the remote system running Solaris CDE.
