Solaris Common Desktop Environment: Advanced User's and System Administrator's Guide
Adding the AnswerBook Package from the Network
When installing Solaris CDE, the installation menu gives you the option to install the AnswerBook CDE package. If you choose YES, the AnswerBook package is installed in the /usr/dt/share/answerbooks/language directory (language is the local name of the particular AnswerBook translation).
Since the AnswerBook package requires 109 megabytes of disk space, you may not want to install it. However, the following two options are available:
	export AB_CARDCATALOG=/net/hostname/usr/dt/share/answerbooks \
    /language/ab_cardcatalog
