The default printer is accessed when the user:
Drops an object on the Front Panel Printer control
Selects an object in File Manager and chooses Print from the Selected menu or the icon's pop-up menu
Prints from applications that use the default printer
To change the default printer for all users:
Open the file /etc/dt/config/Xsession.d/0010.dtpaths.
If /etc/dt/config/Xsession.d/0010.dtpaths does not exist, copy it from /usr/dt/config/Xsession.d/0010.dtpaths.
In the LPDEST=printer line, update printer to the new destination for default printing.
If the line does not exist, add a line LPDEST=printer, where printer is the name of the printer you want to be your default printer.
Users need to log out and back in.
To change the default printer for a single user, that user should:
Copy another printer to the Front Panel from the Personal Printers subpanel.
To designate a different printer as your default printer:
Go to your home folder and open the file .dtprofile.
Add or edit a line that sets a value for the LPDEST
environment variable:
LPDEST=printer_device; export LPDEST
If you are using csh the syntax is:
setenv LPDEST printer_device
For example, the following line would change the default printer to the printer whose device name is laser3d.
LPDEST=laser3d; export LPDEST
setenv LPDEST laser3d
