Solaris Common Desktop Environment: Advanced User's and System Administrator's Guide
Configuring the Application Group To Use a Unique Icon
The desktop provides a default application-group icon. However, you will probably want to provide a custom icon.
If you want to provide a unique icon for the application group, you must create:
Figure 5–9 How an application group gets a unique icon
Graphic
You should also create an Open and Print action for the application group data type:
ACTION Open
 	ARG_TYPE			Media_ToolsAppGroup
 	TYPE				MAP
 	MAP_ACTION		OpenAppGroup
ACTION Print
 	TYPE				MAP
 	MAP_ACTION		PrintAppGroup
OpenAppGroup and PrintAppGroup actions are built-in actions defined in /usr/dt/appconfig/types/language/dtappman.dt.
