Solaris Common Desktop Environment: Advanced User's and System Administrator's Guide
Step 5: Putting the Help Files in the Registration Package
Note –
For an example of adding help files to a registration package, see Step 5 of Example of Creating a Registration Package.
If the application includes a desktop help volume (a help volume created with the desktop Help Developer's Kit), the help volume master file (*.sdl) should be placed in the directory app_root/appconfig/help/language.
Graphics used by the help files are usually placed in a graphics subdirectory. The graphics must be located in the same directory relative to the master help volume (*.sdl) file as when the help volume was created.
If the application does not provide a help volume, you can create one if you have the Help Developer's Kit.
There are two levels of integration of a help volume:
