Solaris Common Desktop Environment: Advanced User's and System Administrator's Guide
To Register an Application with dtappintegrate
If the application is desktop-smart, dtappintegrate is usually run automatically as the final step in the installation process. If it is not run automatically, or if you have created the configuration files to integrate a non-desktop smart application, then you can run dtappintegrate manually.
  1. Log in as root.
  2. Run the command:
    	/usr/dt/bin/dtappintegrate -s  app_root
    where app_root is the desktop application root directory. For more information, see the dtappintegrate(1) man page.
  3. Open the Desktop_Tools application group and double-click Reload Applications.
  4. Verify that the application is properly registered:
    1. Display the top level of the Application Manager. The new application group should appear in the Application Manager.
    2. Open the application group and double-click the action icon.
Syntax and Options for dtappintegrate
dtappintegrate -s app_root [-t target_path ] [-l language ] [-u]
-s app_root
Required parameter, specifies the application root under which the appication has been installed.
-t target_path
Optional parameter, defaults to the system location /etc/dt/appconfig. Specifies the location to which the desktop configuration files are linked. You must use a location on the application search path.
-l language
Optional parameter, defaults to all languages. Specifies which language-dependent desktop configuration files to integrate.
-u
Optional parameter, un-integrates the application, removing all the links set up during integration.
