Solaris Common Desktop Environment: Advanced User's and System Administrator's Guide
Steps to Registering ``BestTextEditor''
The following step-wise procedure registers BestTextEditor.
  1. Modify font and color resources.
    In BestTextEditor's app-defaults file, remove resources that set:
    • Fonts for text
    • Colors for foreground and background
  2. Create the application root.
    Create the directory:
    	/desktop_approots/BTE
    If you are integrating an existing application, you should create the application root directory elsewhere than in the installation location for the application; otherwise, the configuration files you create may be removed when you update the application.
  3. Create the registration package directories.
    Create these directories:
    	/desktop_approots/BTE/dt/appconfig/types/C
     	/desktop_approots/BTE/dt/appconfig/help/C
     	/desktop_approots/BTE/dt/appconfig/icons/C
     	/desktop_approots/BTE/dt/appconfig/appmanager/C/BestTextEditor
  4. Create the actions and data types for the application.
    1. Create the configuration file for the action and data type definitions:
          /desktop_approots/BTE/dt/appconfig/types/C/BTE.dt
    2. Create the action definition for running BestTextEditor:
      ACTION BTEditor
              WINDOW_TYPE    NO_STDIO
              ICON           BTERun
              DESCRIPTION    Double-click this icon or drop \
                             a BTE data file on it to run \
                             BestTextEditor.
              EXEC_STRING    /usr/BTE/BTEd %Arg_1%
    3. Create the data type for *.bte files:
      DATA_ATTRIBUTES BTEDataFile
              DESCRIPTION				BestTextEditor data file.
              ICON						BTEData
              ACTIONS					Open,Print
              DATA_CRITERIA BTEDataFileCriteria1
              DATA_ATTRIBUTES_NAME    BTEDataFile
              NAME_PATTERN    *.bte
              MODE        f
    4. Create the data type for *.tpl files:
      		DATA_ATTRIBUTES BTETemplateFile
       				DESCRIPTION			BestTextEditor template file.
       				ICON					BTETempl
       				ACTIONS				Open
       		DATA_CRITERIAL BTETemplateFileCriteria1
       				DATA_ATTRIBUTES_NAME			BTETemplateFile
       				NAME_PATTERN						*.tpl
       				MODE									f
    5. Create the Open action for *.bte files.
      		ACTION Open
       				ARG_TYPE			BTEDataFile
       				TYPE				MAP
       				MAP_ACTION		BTEditor
    6. Create the Print action for *.bte files.
      Here are simple Print actions that will print the data files. These actions require a value for the LPDEST environment variable and ignore the -s print option. (If LPDEST isn't set, the action may fail.)
      		ACTION Print
       				TYPE					MAP
       				MAP_ACTION			BTEPrintData
      		ACTION BTEPrintData
       		{ 		WINDOW_TYPE				NO_STDIO
       				EXEC_STRING				BTEPrint -d $LPDEST %Arg_1%
      Here is another version of the BTEPrintData action and an accompanying script. Together, they handle situations where LPDEST is not set or if silent printing is requested.
      		ACTION BTEPrintData
       				EXEC_STRING				/usr/BTE/bin/BTEenvprint \
       											%(File)Arg_1%
      The contents of the /usr/BTE/bin/BTEenvprint script are:
      		# BTEenvprint
       		#!/bin/sh
       		DEST=””
       		SILENT=””
       		if [ $LPDEST ] ; then
       			DEST=”-d $LPDEST”
       		fi
       		BTEPrint $DEST SILENT $1
    7. Create the Open action for *.tpl files:
      		ACTION Open
       				ARG_TYPE			BTETemplateFile
       				TYPE				MAP
       				MAP_ACTION		BTEditor
    8. Create the Print action for *.tpl files:
      		ACTION Print
       				ARG_TYPES		BTETemplateFile
       				TYPE				MAP
       				MAP_ACTION		NoPrint
      NoPrint is a built-in action that displays a dialog box telling the user the file cannot be printed.
  5. Put the help files into the registration package.
    1. Place the help files in the following locations:
      		/desktop_approots/BTE/dt/appconfig/help/C/BTEHelp.sdl
       		/desktop_approots/BTE/dt/appconfig/help/C/graphics/BTE1.xwd
       		/desktop_approots/BTE/dt/appconfig/help/C/graphics/BTE2.xwd
    2. Create the file:
      		/desktop_approots/BTE/dt/appconfig/types/C/BTEhelp.dt.
      Put the following action definition in the file:
      		ACTION BTEHelp
              EXEC_STRING    /usr/dt/bin/dthelpview -helpVolume \
                  BTEHelp.sdl
              DESCRIPTION    Opens the BestTextEditor help volume.
  6. Create icons for the application.
    Use Icon Editor to create the icons. Table 5–3 shows the size guidelines to use.
    Table 5–3 Icon Size Guidelines
    Name
    Size
    basename.t.pm
    16 by 16
    basename.m.pm
    32 by 32
    basename.l.pm
    48 by 48
    Create these icon files in the directory /desktop_approots/BTE/dt/appconfig/icons/C:
    • Icons to represent the action that runs the application: BTERun.t.pm, BTERun.m.pm, BTERun.l.pm
    • Icons to represent *.bte files: BTEData.t.pm, BTEData.m.pm,
    • Icons to represent *.tpl files: BTETempl.t.pm, BTETempl.m.pm
    • Icons to represent the application group (used in step 7): BTEApp.t.pm, BTEApp.m.pm
  7. Create the application group.
    1. If you haven't already done so, create the directory.
    2. This step is optional. It provides a unique icon for the application group icon by creating a data type and associated actions for the application group. If you omit this step, the application group will use the default icon.
      Add the following data type and action definitions to the file /desktop_approots/BTE/dt/appconfig/types/C/BTE.dt. The data type specifies the icon to be used by the BestTextEditor application group. The actions provide the same Open and Print behavior as the built-in application groups.
      		DATA_ATTRIBUTES BestTextEditorAppGroup
       				ACTIONS		OpenInPlace,OpenNewView
       				ICON			BTEApp
      		DATA_CRITERIA BestTextEditorAppGroupCriterial
       				DATA_ATTRIBUTES_NAME	BestTextEditorAppGroup
       				MODE							d
       				PATH_PATTERN				*/appmanager/*/BestTextEditor
      		ACTION Open
       				ARG_TYPE				BestTextEditorAppGroup
       				TYPE					MAP
       				MAP_ACTION			OpenAppGroup
      		ACTION Print
       				TYPE					MAP
       				MAP_ACTION			PrintAppGroup
    3. Create an icon in the application group that will start the application. To do this, create the file:
      		/desktop_approots/BTE/dt/appconfig/appmanager/C \
       		/BestTextEditor/BTEditor
      and make the file executable.
    4. Create the action file in the application group that will open the help volume. To do this, create the file:
       		/BestTextEditor/BTEHelp
    5. Put other files into the application group; for example, “read me” files, sample data and template files.
  8. Register the application.
    In a terminal emulator window:
    1. Log in as root.
    2. Run the command:
      		/usr/dt/bin/dtappintegrate -s /desktop_approots/BTE
    3. Open the Desktop_Tools application group and double-click Reload Applications.
