To set system-wide environment variables, create a file in the /etc/dt/config/Xsession.d directory that sets and exports the variable.
For example, if you create an executable ksh script, /etc/dt/config/Xsession.d/myvars, containing:
export MYVARIABLE="value"
then the variable MYVARIABLE
will be set in each user's environment at the next login.
For example:
sets the variable MYVARIABLE
Session Manager does not automatically read the .profile or .login file. However, it can be configured to use these files; see Optionally Sourcing the .profile or .login Script.
