Solaris Common Desktop Environment: Advanced User's and System Administrator's Guide
Workspace Manager Configuration Files
The Workspace Manager gets information about the window menus, workspace menus, button bindings, and key bindings from a configuration file.
It uses one of the following files:
The Workspace Manager searches for a configuration file in the order shown above, and uses the first one it finds.
For users who use more than one session language, a personal, language-dependent configuration file HomeDirectory/.dt/language/dtwrmc can be created that takes precedence over HomeDirectory/.dt/dtwmrc.
To Create or Modify a Personal Configuration File
The personal Workspace Manager configuration file is HomeDirectory/.dt/dtwmrc. If this file exists, it is the file used.
  1. Double-click Edit Dtwmrc in the Desktop_Tools application group.
    If you already have a personal dtwmrc file, it is loaded into the editor. If not, sys.dtwmrc is copied to HomeDirectory/.dt/dtwmrc, which is then loaded into the editor.
  2. Edit the file.
  3. Exit the editor.
    The file is saved as your personal dtwmrc, regardless of its original source.
To Create a System-Wide Configuration File
The system-wide Workspace Manager configuration file is /etc/dt/config/language/sys.dtwmrc.
    Copy /usr/dt/config/language/sys.dtwmrc to /etc/dt/config/language/sys.dtwmrc.
Note –
This file is not used if HomeDirectory/.dt/dtwmrc exists.
To Include (Source In) Other Files
    Use the syntax:
	include
   	   path
  	   path
For example, the following lines source in the file /users/ellen/mymenu:
include
   	 /users/ellen/mymenu
Include statements are useful for providing additional functionality without copying the entire configuration file. For example, a user might want to create a new key binding without having to administer the entire configuration file. The user can create a file HomeDirectory/.dt/dtwmrc with this content:
include
  /etc/dt/config/C/sys.dtwmrc
Keys DtKeyBindings
   Alt<Key>F5 root  f.menu  Applications
Menu Applications
   "GraphicsApp" f.exec "/usr/bin/GraphicsApp/GApp"
To Restart the Workspace Manager
The Workspace Manager must be restarted in order for changes made to the configuration file to take effect.
    Choose Restart Workspace Manager from the Workspace menu (press mouse button 3 when the pointer is on the backdrop).
