Solaris Advanced User's Guide
User Profile
This section describes some of the more commonly used environment variables. Many of these variables might already be in your user profile. As previously mentioned, your user profile file is located in your home directory.
Note –
To view hidden (“dot”) files, use the -la options of the ls command.
The following is a partial list of environment variables that you can include in your user profile. Your current shell determines the syntax for defining environment variables.
