The basic form of the ex copy command is:
:line#,line# co line# |
The first two numbers (separated by a comma) specify the range of lines to be copied. The third number is the line before the insertion point.
For example, to copy lines 1 through 5 of paint and place the copy after line 12, you would type the following:
:1,5 co 12 |
Then press Return.
When you specify line ranges, use the abbreviations:
Thus, to copy the range “from the current line through line 5” and insert this block after line 12, you would type:
:.,5 co 12 |
To copy the range “from line 6 through the end of the file” and insert this block after line 2, you would type:
:6,$ co 2 |
