Solaris Advanced User's Guide
Searching for Metacharacters
To use the grep command to search for metacharacters such as & ! . * ? and \, precede the metacharacter with a backslash (\). The backslash tells grep to ignore (escape) the metacharacter.
For example, the following expression matches lines that start with a period, and is useful when searching for nroff or troff formatting requests (which begin with a period).
$ grep ^\.
Table 4–1 lists common search pattern elements you can use with grep.
Table 4–1 grep Search Pattern Elements
The beginning of a text line
The end of a text line
Any single character
Any single character in the bracketed list or range
Any character not in the list or range
Zero or more occurrences of the preceding character or regular expression
Zero or more occurrences of any single character
The escape of special meaning of next character
Note that you can also use these search characters in vi text editor searches.
