Solaris Advanced User's Guide
Chapter 4 Searching Files
This chapter describes how to search directories and files for keywords and strings by using the grep command.
Searching for Patterns With grep
To search for a particular character string in a file, use the grep command. The basic syntax of the grep command is:
$ grep string file
In this example, string is the word or phrase you want to find, and file is the file to be searched.
Note –
A string is one or more characters. A single letter is a string, as is a word or a sentence. Strings can include blank spaces, punctuation, and invisible (control) characters.
For example, to find Edgar Allan Poe's telephone extension, type grep, all or part of his name, and the file containing the information:
$ grep Poe extensions
Edgar Allan Poe     x72836
Note that more than one line might match the pattern you give.
$ grep Allan extensions
David Allan         x76438
$ grep Al extensions
Louisa May Alcott   x74236
David Allan         x76438
grep is case sensitive; that is, you must match the pattern with respect to uppercase and lowercase letters:
$ grep allan extensions
David Allan         x76438
Note that grep failed in the first try because none of the entries began with a lowercase a.
grep as a Filter
You can use the grep command as a filter with other commands, enabling you to filter out unnecessary information from the command output. To use grep as a filter, you must pipe the output of the command through grep. The symbol for pipe is “|”.
The following example displays files that end in “.ps” and were created in the month of September.
$ ls -l *.ps | grep Sep
The first part of this command line produces a list of files ending in .ps.
$ ls -l *.ps
-rw-r--r--   1 user2    users     833233 Jun 29 16:22
-rw-r--r--   1 user2    users      39245 Sep 27 09:38
-rw-r--r--   1 user2    users     608368 Mar  2  2000
-rw-r--r--   1 user2    users     827114 Sep 13 16:49
The second part of the command line pipes that list through grep, looking for the pattern Sep.
| grep Sep
The search provides the following results.
grep With Multiword Strings
To find a pattern that is more than one word long, enclose the string with single or double quotation marks.
$ grep “Louisa May” extensions
The grep command can search for a string in groups of files. When it finds a pattern that matches in more than one file, it prints the name of the file, followed by a colon, then the line matching the pattern.
$ grep ar *
actors:Humphrey Bogart
alaska:Alaska is the largest state in the United States.
wilde:book.  Books are well written or badly written.
Searching for Lines Without a Certain String
To search for all the lines of a file that do not contain a certain string, use the -v option to grep. The following example shows how to search through all the files in the current directory for lines that do not contain the letter e.
$ ls
actors    alaska    hinterland    tutors    wilde
$ grep -v e *
actors:Mon Mar 14 10:00 PST 1936
wilde:That is all.
Using Regular Expressions With grep
You can also use the grep command to search for targets that are defined as patterns by using regular expressions. Regular expressions consist of letters and numbers, in addition to characters with special meaning to grep. These special characters, called metacharacters, also have special meaning to the system. When you use regular expressions with the grep command, you need to tell your system to ignore the special meaning of these metacharacters by escaping them. When you use a grep regular expression at the command prompt, surround the regular expression with quotes. Escape metacharacters (such as & ! . * $ ? and \) with a backslash (\). See Searching for Metacharacters for more information on escaping metacharacters.
To use the grep command to search for metacharacters such as & ! . * ? and \, precede the metacharacter with a backslash (\). The backslash tells grep to ignore (escape) the metacharacter.
For example, the following expression matches lines that start with a period, and is useful when searching for nroff or troff formatting requests (which begin with a period).
$ grep ^\.
Table 4–1 lists common search pattern elements you can use with grep.
Table 4–1 grep Search Pattern Elements
The beginning of a text line
The end of a text line
Any single character
Any single character in the bracketed list or range
Any character not in the list or range
Zero or more occurrences of the preceding character or regular expression
Zero or more occurrences of any single character
The escape of special meaning of next character
Note that you can also use these search characters in vi text editor searches.
Single or Double Quotes on Command Lines
As shown earlier, you use quotation marks to surround text that you want to be interpreted as one word. For example, type the following to use grep to search all files for the phrase “dang it, boys”:
$ grep "dang it, boys" *
You can also use single quotation marks (') to group multiword phrases into single units. Single quotation marks also make sure that certain that the system interprets metacharacters, such as $, literally.
Note –
The history metacharacter ! is always interpreted as a metacharacter, even inside quotation marks, unless you escape it with a backslash.
Escape characters such as & ! $ ? . ; and \ when you want grep to interpret these characters as ordinary typographical characters.
For example, if you type the following command, the system displays all the lines in the file list.
$ grep $ list
However, if you type the following command, the system displays only those lines that contain the “$” character.
$ grep '\$' list
For more information on the grep(1) command, refer to the man Pages(1): User Commands.
