ONC+ Developer's Guide
AUTH_SYS Authentication
The client can use AUTH_SYS style authentication (called AUTH_UNIX in previous releases) by setting clnt–>cl_auth after creating the RPC client handle:
clnt->cl_auth = authsys_create_default();
This setting causes each RPC call associated with clnt to carry with it the following credentials-authentication structure shown in the following example:
Example 5–7 AUTH_SYS Credential Structure
 * AUTH_SYS flavor credentials.
struct authsys_parms {
	u_long aup_time;			 /* credentials creation time */
	char *aup_machname;		 /* client's host name */
	uid_t aup_uid;				 /* client's effective uid */
	gid_t aup_gid;				 /* client's current group id */
	u_int aup_len;				 /* element length of aup_gids*/
	gid_t *aup_gids;			 /* array of groups user is in */
rpc.broadcast defaults to AUTH_SYS authentication.
The following example shows a server, with procedure RUSERPROC_1(), that returns the number of users on the network. As an example of authentication, the server checks AUTH_SYS credentials and does not service requests from callers with a uid of 16.
Example 5–8 Authentication Server
nuser(rqstp, transp)
	struct svc_req *rqstp;
	SVCXPRT *transp;
	struct authsys_parms *sys_cred;
	uid_t uid;
	unsigned int nusers;
	/* NULLPROC should never be authenticated */
	if (rqstp->rq_proc == NULLPROC) {
		if (!svc_sendreply( transp, xdr_void, (caddr_t) NULL))
			fprintf(stderr, "can't reply to RPC call\n");
	/* now get the uid */
	switch(rqstp->rq_cred.oa_flavor) {
		case AUTH_SYS:
			sys_cred = (struct authsys_parms *) rqstp->rq_clntcred;
			uid = sys_cred->aup_uid;
	switch(rqstp->rq_proc) {
		case RUSERSPROC_1:
			/* make sure caller is allowed to call this proc */
			if (uid == 16) {
			 * Code here to compute the number of users and assign it
			 * to the variable nusers
			if (!svc_sendreply( transp, xdr_u_int, &nusers))
Note the following points about the example:
The last point underscores the relation between the RPC authentication package and the services: RPC deals only with authentication and not with an individual service's access control. The services must establish access-control policies and reflect these policies as return statuses in their protocols.
