Batched Code Example
Example D–11 Batched Client Program
#include <stdio.h>
#include <rpc/rpc.h>
#include "windows.h"
main(argc, argv)
int argc;
char **argv;
struct timeval total_timeout;
register CLIENT *client;
enum clnt_stat clnt_stat;
char buf[1000], *s = buf;
if ((client = clnt_create(argv[1], WINDOWPROG, WINDOWVERS,
"CIRCUIT_V")) == (CLIENT *) NULL) {
clnt_pcreateerror("clnt_create");
exit(1);
timerclear(&total_timeout);
while (scanf("%s", s) != EOF) {
clnt_call(client, RENDERSTRING_BATCHED, xdr_wrapstring,
&s,xdr_void, (caddr_t) NULL, total_timeout);
/* Now flush the pipeline */
total_timeout.tv_sec = 20;
clnt_stat = clnt_call(client, NULLPROC, xdr_void,
(caddr_t) NULL, xdr_void, (caddr_t) NULL,
total_timeout);
if (clnt_stat != RPC_SUCCESS) {
clnt_perror(client, "rpc");
exit(1);
clnt_destroy(client);
exit(0);
Example D–12 Batched Server Program
#include <stdio.h>
void windowdispatch();
main()
int num;
num = svc_create(windowdispatch, WINDOWPROG, WINDOWVERS,
"CIRCUIT_V");
if (num == 0) {
fprintf(stderr, "can't create an RPC server\n");
exit(1);
svc_run(); /* Never returns */
fprintf(stderr, "should never reach this point\n");
void
windowdispatch(rqstp, transp)
struct svc_req *rqstp;
SVCXPRT *transp;
char *s = NULL;
switch (rqstp->rq_proc) {
case NULLPROC:
if (!svc_sendreply(transp, xdr_void, 0))
fprintf(stderr, "can't reply to RPC call\n");
return;
case RENDERSTRING:
if (!svc_getargs(transp, xdr_wrapstring, &s)) {
fprintf(stderr, "can't decode arguments\n");
/* Tell caller an error occurred */
svcerr_decode(transp);
break;
/* Code here to render the string s */
if (!svc_sendreply(transp, xdr_void, (caddr_t) NULL))
break;
case RENDERSTRING_BATCHED:
/* Be silent in the face of protocol errors */
break;
/* Code here to render string s, but send no reply! */
break;
default:
svcerr_noproc(transp);
return;
/* Now free string allocated while decoding arguments */
svc_freeargs(transp, xdr_wrapstring, &s);
